Old 03-04-2014, 02:58 PM   #1
chevychase
chevychase's Avatar
Gauge Cluster Year Compatability
Will a 1987 gauge cluster which is TBI, be used in a 1986 non TBI C10?
Joe
chevychase is offline   Reply With Quote
Old 03-04-2014, 05:28 PM   #2
b454rat
Re: Gauge Cluster Year Compatability
Yup, 1979-up will work, course 79 will have different font, but will work. Up to 90 will work, 91 has VSS instead of cable.....
Old 03-04-2014, 08:06 PM   #3
chevychase
chevychase's Avatar
OK, cool... thanks b454rat, I appreciate it!
Joe
Old 03-04-2014, 08:51 PM   #4
Kaotik Kustumz
Kaotik Kustumz's Avatar
But make sure if your truck has gauge option the other cluster MUST have gauge option also....
Gauge option - volts, oil pressure and water temp.
Non Gauge option - dummy lights
KAOTIK Kustumz
1984 Chevy 1 Ton Crew Cab Dually "Western Hauler"454, th400, (6.0, 4l80e Swap Coming Soon)(5/7 Drop Coming Soon) (ON HOLD FOR NOW)
1986 Chevy 1/2 Ton LWB Silverado350, 700r4, (5.3, 4l60e Swap Coming Soon)(4/6 Drop)
Kaotik Kustumz is offline   Reply With Quote
Old 03-05-2014, 01:58 AM   #5
Irish1941
Irish1941's Avatar
Not being a stickler but '89 was last yr for cable driven speedo and VSS. '90-'91 went to electric speedos and Digital Ratio Adapter Controller (DRAC) setup.
VSS cluster no has effect on early trucks. It was for cruise & ECM signals to control the EFI or ESC. It's just a optical signal that reads off the speedo.
Irish1941 is offline   Reply With Quote
Old 03-05-2014, 01:16 PM   #6
chevychase
chevychase's Avatar
Hmmm... not sure. When I got the truck (86 in need of cluster) it didn't have a cluster. Is there anyway to tell?
Joe
Old 03-05-2014, 03:21 PM   #7
RandyP
Getting Old; Going Broke
RandyP's Avatar
The SPID would be a good start. Trim level as well. Good chance if it is a Silverado it had full gauges and if it was a Custom Deluxe it had idiot lights, etc.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 03-05-2014, 03:36 PM   #8
Irish1941
Irish1941's Avatar
Like Randy says…look for RPO Z53 (gauge pkg)
Doesn't really matter though. You don't really need an exact replacement. You can re-pin the plug for gauges and most of them won't even need to be swapped around.
Only wire that really needs attention is the alternator wire if truck didn't have volt gauge.
Check out this thread. Might help you out.
http://67-72chevytrucks.com/vboard/s...d.php?t=491032
Old 03-05-2014, 07:41 PM   #9
chevychase
chevychase's Avatar
Thanks Randy and Irish for the heads up on the SPID/RPO. Unfortunately the truck in need of the cluster is far away in storage so I'll have to wait 'til next time I can get up there.
I'm not sure if the '86 that needs the cluster is a Custom Deluxe or Silverado... now I'm curious!
Good to know worst case I can repin... I'll check out the link now.
Joe
