Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 03-05-2014, 05:50 PM   #1
E.D.75GMC
E.D.75GMC's Avatar
Where does this go?
I know it's part of the horn, but I have no idea where it goes and what it connects to! And it's actually not from my truck, it's from my 89 IROC but couldn't find anything about it elsewhere, and I assume GM used the same horn set up across it's model range in the 80's. I'd love to have an operable horn once again!
(I hope it's okay posting a non-truck question here)
E.D.75GMC is offline   Reply With Quote
Old 03-05-2014, 05:55 PM   #2
Katrina/10
Katrina/10's Avatar
Re: Where does this go?
It goes under your horn cap, into the steering wheel hub.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-05-2014, 08:22 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
Yep, Drop the pin in the small hole in the steering wheel. Then insert the spring end into the hole, The black plastic piece has ears on it to slide in and twist lock it in. Plug the wire into the back of your horn button then your good to go......
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-06-2014, 02:47 PM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Above comments are true but depends on which horn cap and wheel you're using
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
