greasing new fuel pump
hey i'm about ready to put a new mechanical fuel pump on my 350 and have heard to grease it first. Do you guys do this and if so what kind of grease do you use. Thanks
Rust is better than rice. ![]() |
Re: greasing new fuel pump
I have always filled the inside with bearing grease, not sure what it does or if it is needed. Something my dad told me and have just always did it.
![]() 1985 C10 2004 Avalanche |
The grease also helps hold the gasket on till you get it mounted.
![]() Join Date: Feb 2000
The only thing I've put grease on is the pump push rod to help hold it up inside the engine while installing the pump. Engine oil should do the lubricating that is required.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Grease doesn't break down in engine oil. I hope you mean lubriplate or assembly lube.
i do my burn outs in 4wd ![]() |
