04-09-2014, 11:54 AM | #501 |
Re: My new project 86 Silverado
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
04-16-2014, 09:25 AM | #502 |
i block sanded the epoxy primer on the cab the other day, did it with 80 grit to scuff it up good, then used 180 on it.
shot a shoddy coat of 2K primer on it... cheap gun I have isn't spraying wet enough, so i'm gonna get another one and re-prime the 2K... pic updates after i re-sand/shoot the primer
04-16-2014, 01:33 PM | #503 |
small update
04-16-2014, 07:22 PM | #504 |
I just found the thread, and kinda skipped thru it, good looking truck! Thank you for serving for our country!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
04-16-2014, 08:59 PM | #505 |
thanks for stopping by man
04-16-2014, 09:48 PM | #506 |
Starting to look like a truck again...
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
04-17-2014, 06:39 AM | #507 |
yeah, i'll be glad to start getting this thing back together and wired
04-17-2014, 08:23 PM | #508 |
That's exactly how mine is sitting other than mine has bare doors on it.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
04-23-2014, 07:38 AM | #509 |
talked to my engine builder Monday, they have the long block done, all but the pushrods, they had to order a different length for the new cam.
hopefully they can throw the tins on it in the next few days and get it done, can't wait to get it installed!
04-23-2014, 07:40 AM | #510 |
i'm going to start disassembly of my doors and do them before working on the bed, will make me feel like i'm making progress to get the cab buttoned up
04-23-2014, 06:55 PM | #511 |
That's how I did mine, the bed can wait..lol
05-13-2014, 07:29 PM | #512 |
don't have my camera at the moment, so no pics... but i stripped all the hardware/glass out of the passenger door, and sanded the outside to bare metal, will do the other tomorrow i hope before it rains...
i'll hand sand the hard to get to stuff and hopefully prime them in a day or so... will get the camera from the wife and upload some pics tomorrow
05-13-2014, 07:32 PM | #513 |
my Olds 455 is done, will get down to SC as soon as I can to get it, will be glad to get the damn thing in... only took a year to get it built
05-14-2014, 11:27 AM | #514 | |
Or this the Olds for something else? Looking forward to pictures!
"I feel the need for speed!"... as soon as I am done with my nap. |
05-14-2014, 12:38 PM | #515 |
Dude, its time to take the Christmas lights down, lol...
05-14-2014, 03:32 PM | #516 |
LOL, no way man they're the night light for the wife
05-14-2014, 03:33 PM | #517 |
Olds is until my Poncho 461 is built...
06-27-2014, 10:52 PM | #518 |
Don't remember if i listed my engine's final build info, so here it is...
1976 Oldsmobile 455 that I picked up from my buddy X-cabsquarebody over at c10forum - thanks man I had the following done to it... Block bored .030 over Honed with torque plates Decked Mains align honed Crank turned/polished .010/.010, straightened Factory rods reworked, ARP bolts Factory high compression pistons advertised as 10.25:1 - i'll have to calculate true ratio when I verify the cc of the heads Hastings moly rings Clevite main/rod bearings Melling high volume oil pump/pickup/drive rod Rotating assembly balanced with dampener and flex plate installed Clevite cam bearings Bullet hyd cam - .512 lift 230/284 duration on both int/ex on a 110 LS Matching valve springs 110lbs closed, 285lbs open Cloyes true double roller timing set Heads reworked with new hardware - I had larger 2.07 int and 1.68 exhaust valves installed, performance valve job New lifters/pushrods/rocker arms Stock 4 barrel intake Modified 800cfm Quadrajet, 76 main jets - 48 primary rods - DB secondary rods Chrome valve covers All Felpro gaskets Painted original GM blue 450+ horsepower 500++ torque Nice sleeper Thats about it... if I remember anything else i'll post it Will post pics of it when I pick it up, hopefully soon
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 06-27-2014 at 11:02 PM. Reason: added info |
06-28-2014, 12:27 AM | #519 |
Can't wait to see that!
06-28-2014, 01:11 AM | #520 |
hey man, i can't wait either... i'll be glad to get it in and running, so i can put the front end on my damn truck!
06-28-2014, 10:27 AM | #521 |
Another update...
New parts... Window visors, window trim, and lights
06-28-2014, 11:44 AM | #522 |
I have 2 new 16gal saddle tanks and new sending units for my 86 from Rock Auto...
Would like to trade for an aluminum fuel cell + sending unit that i can mount in the bed... prefer at least 22 gallons
07-01-2014, 08:55 PM | #523 |
took the bed back off.... block sanded the first coat of primer on the cab.... going to spray the second coat tomorrow... going to primer the fenders as well... will post pics after that...
pressure washed the inside of the bed, will start sanding the outside of the bed over the next several days
07-02-2014, 08:28 AM | #524 |
block sanded cab... going to try and put the second coats on here in a bit
07-02-2014, 04:10 PM | #525 |
sprayed 2nd coat of primer on the cab...
sanded the bare metal on the fenders with 180 grit... sprayed the fenders with their 1st coat of primer... sanding the doors to bare metal, hopefully will prime them tomorrow...
