![]() Join Date: Jun 2010
Re: My new project 86 Silverado
Man, sorry to hear about that. Take care of yourself.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
small update
took the bed back off.... block sanded the first coat of primer on the cab.... going to spray the second coat tomorrow... going to primer the fenders as well... will post pics after that...
pressure washed the inside of the bed, will start sanding the outside of the bed over the next several days
block sanded cab... going to try and put the second coats on here in a bit
sprayed 2nd coat of primer on the cab...
sanded the bare metal on the fenders with 180 grit... sprayed the fenders with their 1st coat of primer... sanding the doors to bare metal, hopefully will prime them tomorrow...
