Old 04-18-2014, 01:11 PM   #1
nds1968
nds1968's Avatar
Question Moser Differential Cover / Porterbuilt Stage 2
Does any know if the Moser differential cover 7111 http://www.summitracing.com/parts/msr-7111/overview/ clear the panhard bar on the Porterbuilt Stage 2 http://www.summitracing.com/parts/msr-7111/overview/
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 04-18-2014, 05:36 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Moser Differential Cover / Porterbuilt Stage 2
I have not fit one up before. Do you know how much thicker it is compared to the factory cover?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-18-2014, 06:47 PM   #3
Number98
Prestige Worldwide
Number98's Avatar
It's tough to do this with only 2 hands but it is basically 1" difference....
Number98 is offline   Reply With Quote
Old 04-18-2014, 08:36 PM   #4
nds1968
nds1968's Avatar
Thanks for helping out Nate
Nate
Old 04-18-2014, 09:51 PM   #5
jtp67-72
jtp67-72's Avatar
On mine with extreme drop with inboard bags it hits when chassis is a full height but wont have an effect at ride height or aired out....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 04-18-2014, 11:22 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
Honestly I don't think it's going to clear with the straight bar.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 04-19-2014, 12:13 AM   #7
jtp67-72
jtp67-72's Avatar
I'm assembling mine this weekend..will take pics....barely touches when max raised...jim
Old 04-19-2014, 02:00 PM   #8
Number98
Prestige Worldwide
Number98's Avatar
Would you consider a "bent" bar for clearance, given not much strength is lost?
Old 04-19-2014, 02:01 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
Which kit are you running/planning on running?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 04-19-2014, 02:14 PM   #10
nds1968
nds1968's Avatar
I was gonna buy the cover from Number98. I have the basic stage 2 rear suspension with air bags w/schrader valves. I'm thinking I would like adequate clearance through out the suspension travel.
Nate
Old 04-20-2014, 10:27 AM   #11
PBFAB.COM
PBFAB.COM's Avatar
We could custom bend a bar for you. However you would need to mock the kit up with the straight bar and then get some measurements for us. Should be pretty easy. We have done it before.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 04-21-2014, 02:41 PM   #12
nds1968
nds1968's Avatar
Thanks guys for helping. I'm not stuck on using this cover so I'll have to find one that will work with the straight panhard par. Nate
Nate
Old 04-22-2014, 10:09 AM   #13
msgdsrf
Here's an option
http://www.lpwracing.com/Diff_Cover_...omparison.html
msgdsrf is offline   Reply With Quote
Old 04-23-2014, 10:52 PM   #14
nds1968
nds1968's Avatar
Originally Posted by msgdsrf View Post
Thanks.
The Extra-Low profile design, measures 3-3/8" from gasket surface. Nate do you think this cover will clear?
Nate
Old 04-24-2014, 08:48 AM   #15
Number98
Prestige Worldwide
Number98's Avatar
Thanks.
The stock cover I have is 2-3/4" from the gasket surface Nate.
Old 04-24-2014, 10:26 AM   #16
PBFAB.COM
PBFAB.COM's Avatar
Thanks.
I know that it is pretty tight on the factory cover.
Do me a favor and if you want the bigger cover, buy it. I will work with you in bending a bar that will fit. That way we can offer the bar to all our customers as an option. You deal with a little bit of leg work, measuring, and waiting for a new bar to ship.... and I don't have to worry about mocking it up here in the shop. Little R&D tag team. You get a bar that fits at no extra expense to you. And I get you to work for "free" for a few hours!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 04-24-2014, 05:12 PM   #17
nds1968
nds1968's Avatar
Nate
Sending a PM
Nate
Old 05-01-2014, 08:31 AM   #18
Bennett68C10
Bennett68C10's Avatar
I don't know about the stage 2 but mine fits perfect on my extreme dropmember with the outboard bag mounts. This pic is aired out but I can get a fully aired up pick later tonight if anybody needs it. Sounds like you guys devised a plan of attack to make it fit and once again great customer service from Porterbuilt helping out their clients.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-01-2014, 09:53 AM   #19
jtp67-72
jtp67-72's Avatar
The inboard setup is where it gets tricky...I will post pic tonight of how tight it is .....has to be completely aired up on it's "toes" to touch cover...I don't think it's a problem for me but it will barely rub...jim
Old 05-01-2014, 10:24 AM   #20
PBFAB.COM
PBFAB.COM's Avatar
Also, something to keep in mind, the trac-bar mounting bracket on the frame is located closer to the axle on the Stage 2 kits than the Dropmember kits. It is also at a different height level.
This is why there is so much less clearance on the Stage 2 kits vs the Dropmember kits.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-01-2014, 09:54 PM   #21
jtp67-72
jtp67-72's Avatar
here's the pics.....dropmember...inboard bags....shots were taken with
chassis at nearly full height....which it will really never be..let me know Nate what u think.....if mounting tabs were another hole lower may help this without bending bar........jim
Old 05-02-2014, 09:49 PM   #22
nds1968
nds1968's Avatar
Thanks for your input guys. I took the rearend to get PC yesterday.
Nate
Old 05-09-2014, 05:33 PM   #23
nds1968
nds1968's Avatar
Just an update, I purchased the Moser Engineering Aluminum Differential Cover.
Nate
Old 05-09-2014, 11:31 PM   #24
jtp67-72
jtp67-72's Avatar
Like the one above??
Old 05-10-2014, 05:36 PM   #25
nds1968
nds1968's Avatar
Yeah, Moser Part Number: 7111. I bought a used one on Ebay. Supposedly only used for mockup.
Nate
