Old 05-08-2014, 12:18 PM   #26
soonerfanru2
Re: Think I found a dandy
Thanks everyone Correction it is a 62 on the title. I thought the hood should be different, I know GMC stuff can be different though. That firing order diagram would be great. It is home tucked in the shop, let the fun digging in begin.
soonerfanru2 is offline   Reply With Quote
Old 05-08-2014, 12:21 PM   #27
soonerfanru2
Originally Posted by Captainfab View Post
Welcome to the forum
Yeah, I'd say you found a dandy.....you don't find them that nice very often.
Aside from getting the engine running, I would go through the brakes and make sure they are in good operating condition. The hydraulic clutch and steering would be next on the list.
Captain fab what do I need to do to the clutch and steering?
Old 05-08-2014, 12:26 PM   #28
soonerfanru2
Originally Posted by duallyjams View Post
Nice dandy, make it mechanically safe then maybe upgrade to a alternator.
What all do I have to change to do this? Thanks
Old 05-08-2014, 12:57 PM   #29
RockTonka
RockTonka's Avatar
a little reading here http://6066gmcclub.com/gmcguy/ will go a long way...
Nice truck
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 05-08-2014, 01:09 PM   #30
jtrichard
here is your firing order http://www.autozone.com/autozone/rep...96b43f80cb0c73
jtrichard is offline   Reply With Quote
Old 05-08-2014, 01:21 PM   #31
soonerfanru2
Originally Posted by jtrichard View Post
That didn't show the 305 v6 engine will it be the same as the 265 v6
Old 05-08-2014, 01:32 PM   #32
jtrichard
it appears that it is
Old 05-08-2014, 04:46 PM   #33
65Gregg
65Gregg's Avatar
"What do I need to do first to it to get it back on the road?"
I can't believe no one said that the only way to get it back on the road was to call them to come get it Great find & good luck.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 05-09-2014, 12:06 AM   #34
Captainfab
60-66 Nut
Just check the function of the clutch, which on the '60-'62 is hydraulically operated. The master cylinder on the firewall is 1/2 for the clutch and the other 1/2 is for the brakes. For the steering, check the steering box for excessive slop and check the tierods and idler arm for looseness, If they all check good, I would grease all the tierods, balljoints and control arm bushings. And since you have the grease gun out, may as well grease the U-joints too.
Old 05-09-2014, 03:51 AM   #35
franken
All the above...
I'd add grease all the zerks til new grease comes out, replace all the hoses, including brake flex hoses, and at least flush the brakes.
And plan on new tires if the freeway is in the future.
Personally, I'd lightly wash it, and maybe use some CLR on the rustier bits, then drive it. The goodness of stuff that comes from OK is crazy. It's an hour away but something's different
Old 05-09-2014, 11:47 AM   #36
62 Barnfind
62 Barnfind's Avatar
Nice find! I would do a good cleaning and paint restoration on it. Some things might have to be repainted but the majority looks good. I wish mine look like that when I found it!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 05-10-2014, 02:11 PM   #37
soonerfanru2
Thanks gentlemen for all the responses I've started gathering parts and reading lots of stuff on here can't wait to drive it around the block.
Old 05-10-2014, 02:36 PM   #38
jbgroby
jbgroby's Avatar
Somewhere along the years they charged the '60 hood off of her. She has the 62-66 hood, no biggie though.
jbgroby is offline   Reply With Quote
Old 05-10-2014, 05:11 PM   #39
soonerfanru2
I corrected that at the top of this page it is a 1962. The master cylinder was all gunked up and clutch stays on the floor. I think the clutch may be stuck to the flywheel can't seem to get it unstuck or it's not out of gear. Making it hard to turn the engine over with a socket. I poured marvel mystery oil down the spark plug holes may just need to let it set a few days. Sure seems tight right now hope it frees up.
