Old 05-08-2014, 12:07 AM   #1
soonerfanru2
Think I found a dandy
Bringing this 1960 GMC home tomorrow. One owner 64000 actual miles been covered up most of its life. Rats have eat the spark plug wires and hasn't been started in years. Original paint and only rust is below the window drip rail an easy fix. V6 3 speed on the column, has the original spare and hubcaps. Dealer book in glove box. What do I need to do first to it to get it back on the road?
soonerfanru2 is offline   Reply With Quote
Old 05-08-2014, 12:08 AM   #2
soonerfanru2
Re: Think I found a dandy
Another pic
Old 05-08-2014, 12:09 AM   #3
soonerfanru2
And another
Old 05-08-2014, 12:10 AM   #4
soonerfanru2
Engine bay
Old 05-08-2014, 12:41 AM   #5
terbronco7
terbronco7's Avatar
Nice find! Good lookin truck.
terbronco7 is offline   Reply With Quote
Old 05-08-2014, 12:41 AM   #6
Captainfab
60-66 Nut
Welcome to the forum
Yeah, I'd say you found a dandy.....you don't find them that nice very often.
Aside from getting the engine running, I would go through the brakes and make sure they are in good operating condition. The hydraulic clutch and steering would be next on the list.
Old 05-08-2014, 01:04 AM   #7
LT1 Burb
LT1 Burb's Avatar
Very nice, DO NOT lift the rubber floor mat to look at the floors, you will tear it and hate yourself.
LT1 Burb is offline   Reply With Quote
Old 05-08-2014, 06:55 AM   #8
PGSigns
PGSigns's Avatar
Good looking truck. I would start with cleaning the fuel system and getting it so you can spin it over. Pull the plugs out of it and spin the thing over to get the oil back up into everything. Then do a compression check to see if it is good to go. Tun it up and get it running. Next Like Captian fab said go through the brakes. I would replace the master cylinder, all the hoses and wheel cylinders and put new shoes on it. While doing that take a real good look at the lines for rust near the fittings.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-08-2014, 07:20 AM   #9
chakah
chakah's Avatar
You might wanna check the gas tank, you don't need any old gas going through that carb. Might need a flush. Great find, congratulations.
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 05-08-2014, 08:08 AM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
if the plug wires are eaten, check all the wiring. nice find!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-08-2014, 08:23 AM   #11
63burban
Chevy addict
Nice find, they're still out there !
63burban is offline   Reply With Quote
Old 05-08-2014, 08:26 AM   #12
1963c-10
1963c-10's Avatar
Welcome and great looking GMC. Nice score on a great original truck.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-08-2014, 08:29 AM   #13
soonerfanru2
Will I need to pour anything in the spark plug holes to lubricate the pistons first? And does it have a hydrolic clutch. And does anyone have a diagram so I can get the plug wires back in the right order. And keep all the comments coming this forum is great!
Old 05-08-2014, 08:41 AM   #14
Jeff La
And another to be revitalized, nice find
Jeff La is offline   Reply With Quote
Old 05-08-2014, 09:45 AM   #15
Ta2Don
Ta2Don's Avatar
Great Score!!! Another one Saved!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 05-08-2014, 09:56 AM   #16
duallyjams
duallyjams's Avatar
Nice dandy, make it mechanically safe then maybe upgrade to a alternator.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-08-2014, 10:19 AM   #17
encasedmetal
awesome- same color as my 63' gmc
encasedmetal is offline   Reply With Quote
Old 05-08-2014, 10:31 AM   #18
96Indyram
96Indyram's Avatar
Great find!
I would pull the plugs and put some pbblaster or marvel mystery oil into the cylinders.
then put a socket on the harmonic balance bolt and turn it over by hand. Since it has sat so long the rings might have stuck to the cylinder walls... if it spins free you know nothing internal is damaged ( broke rod or spun bearings)
And clean the gas tank and blow out the fuel line. You will probably have to rebuild the carburetor because all the gaskets have dried up and will leak fuel.
Take your time and enjoy the project.
66 c10 Panel (Wife's)
http://67-72chevytrucks.com/vboard/s...d.php?t=595684
68 c10 LWB
96Indyram is offline   Reply With Quote
Old 05-08-2014, 10:45 AM   #19
Pappyx3!
Pappyx3!'s Avatar
Sweet Find! Welcome to the forum.
Look forward to seeing what you do with it...
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline   Reply With Quote
Old 05-08-2014, 10:46 AM   #20
glos55
glos55's Avatar
Awesome find!!!!
LIFE IS SHORT HAVE FUN
glos55 is offline   Reply With Quote
Old 05-08-2014, 10:50 AM   #21
TJ's Chevy
TJ's Chevy's Avatar
Great dandy of a find! Looks to be all original!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-08-2014, 11:03 AM   #22
b.sharp
b.sharp's Avatar
If no one can support the firing order, I can get pictures this weekend. I have one of these at the farm. There are a few on the board and surely someone will chime in. Great looking truck. I would love to find one this clean for a daily driver.
b.sharp is offline   Reply With Quote
Old 05-08-2014, 11:10 AM   #23
firemanjimtfd
firemanjimtfd's Avatar
Welcome and glad to see another Oklahoma truck rescued.
firemanjimtfd is offline   Reply With Quote
Old 05-08-2014, 11:16 AM   #24
jchav62
1962 C-10
jchav62's Avatar
Very nice find! Congrats....
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-08-2014, 12:16 PM   #25
TopFuel1966
TopFuel1966's Avatar
X 2 what 96 Indy said. If the motor hasn't run in a long time and if it were mine before I tried to start it I would drain all the old nasty oil out of it and put in fresh oil including some Marvel Mystery oil and a new filter. This will further help to free up any stuck rings and valves. Do another oil change after 500 miles or so.
Speaking of valves, pop the valve covers and make sure that none of the valve stems are stuck in the guides and put a little oil on the stems while you turn the motor over by hand.
TopFuel1966 is offline   Reply With Quote
