Old 05-11-2014, 06:43 PM   #1
jonnymel
1960 exhuast question
Hi Guys
I have a 1960 gmc stepside. I am installing a fresh 454 and am looking for exhaust solutions. I would love some input.
My ideas .......would love to install headers and sidepipes or headers and duals out the back. Does anyone know what headers or sidepipes could work.
Or anyone have some ideas or alteratives.
jonnymel is offline   Reply With Quote
Old 05-11-2014, 07:57 PM   #2
Brad54
Brad54's Avatar
Re: 1960 exhuast question
The problem you'll have is routing: the pipes have to run through/under the torsion-bar cross member/X-frame.
What I did is kept the stock exhaust manifolds, ran them down and installed an X-pipe, then ran them back and had them exit the sides ahead of the wheel openings.
You could use block-hugger headers and an X-pipe, and it'd fit everything real nice, and real clean.
Because of the way things run down there, the '60-'62 trucks had a removable trans tunnel, and to service the trans, the tunnel had to come out and the trans was lifted out through the hole in the floor.
On the next go-round with my truck, I'm going to put 2.5-inch Rams Horns and the X-pipe and run them out the back, dumping out the sides right ahead of the rear bumper.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 05-11-2014, 08:34 PM   #3
LVPhotos
LVPhotos's Avatar
Check my build thread. I have mine run down middle like x and mufflers in middle. Plus the old side pipes had ram horns and went above torsion bars.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-11-2014, 11:01 PM   #4
jonnymel
Thanks guys
I love the side pipes ..... That's the way I'd like to do it. Just not sure what manifold or header to use and if there is room with the big block.
Old 05-12-2014, 12:18 PM   #5
LVPhotos
LVPhotos's Avatar
First its going to be loud. Second the side pipes I had blew out with the 406 small block at 9.5:1 compression. Here are some considerations... Always call to confirm this will work.
http://www.speedwaymotors.com/Big-Bl...ack,57751.html
http://www.speedwaymotors.com/Garage...ted,74214.html
http://www.speedwaymotors.com/Side-P...-Kit,5423.html
http://www.cherrybomb.com/project_ve...68_camaro.aspx
http://www.summitracing.com/search/p...ust-side-pipes
Old 05-12-2014, 12:21 PM   #6
LVPhotos
LVPhotos's Avatar
Old 05-12-2014, 08:02 PM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: 1960 exhuast question
Pics Of Exhaust on 60-62 with Torsion Bars
http://67-72chevytrucks.com/vboard/s...d.php?t=502288
Lets hear some different exhaust setups on your 1960 - 1966 Chevrolet & GMC Pickups
http://67-72chevytrucks.com/vboard/s....php?p=6514266
Show me your exhaust
http://67-72chevytrucks.com/vboard/s...d.php?t=345206
Exhaust search:
http://www.google.com/custom?domains...D%3A1%3B&hl=en
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 05-15-2014, 07:05 PM   #8
jonnymel
Thanks for the info .....I think i have it sorted now.
Jon
