Old 05-27-2014, 09:46 AM   #1
Orion88
Orion88's Avatar
sound deadener/heat shield: best bang for your buck, how many square feet?
Before I redo my interior I figured I'd lay some sound deadening mats in my 79 C10. What is a good brand that's actually affordable? Things like dynamat and lizard skin are a little pricey in my opinion. I was leaning towards Eastwood or summit racing brand. also, how many square feet do I need to do my cab? The truck will have about as aggressive of an exhaust as you'd want in a truck you drive every day, and it will have a quality sound system by the time it's all said and done.
You gotta have fun while you're little!!
Orion88 is offline   Reply With Quote
Old 05-27-2014, 04:05 PM   #2
tinydb84
tinydb84's Avatar
Re: sound deadener/heat shield: best bang for your buck, how many square feet?
Dynamat isn't a sound deadener. It will reduce the resonance but wont do as much to decrease the volume. What you want is a small amount of dynamat (think like 20% on the large flat panels) followed by closed cell foam then mass loaded vinyl. If you are skipping on any of it skip the dynamat.
David
Instagram: myfabguy
Old 05-27-2014, 05:01 PM   #3
Orion88
Orion88's Avatar
Well the dynamat also helps significantly reduce heat so I was planning on covering my whole floor and firewall to help reduce cab heat in the summer. But buying dynamat means you're paying for a brand name. I was just curious what a good off brand was and how many square feet I need to buy. I will probly try the closed cell foam and vinyl as well. Where do you get that?
Old 05-27-2014, 05:55 PM   #4
tinydb84
tinydb84's Avatar
I have seen fatmat and hushmat for decent prices. You want butyl based and not asphalt based though.
Closed cell foam you can get on ebay/amazon/etc. The vinyl is heavy so you want to find something with cheap shipping. I would check out the automotive audio forums to see where the best deals are.
Sorry cant give you the amount you will need though. Havent done it on a C10 yet.
David
Instagram: myfabguy
Old 05-27-2014, 06:01 PM   #5
carboncrew
carboncrew's Avatar
I am happy with RAAMaudio product.
Their stuff seems really sticky (won't come off in AZ summers), good price, etc...
http://www.raamaudio.com/
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 05-27-2014, 07:07 PM   #6
dieseldawg142
dieseldawg142's Avatar
i used 100 sq ft of fatmat rattletrap, closed c. foam, & mlv when i did my crew.
thats everywhere except the roof. 50 sq ft should do a reg. cab
got my mlv from these guys
http://isostore.com/shop/product/tot...pound-2-pound/
do this 3 stage process & you will be surprised how quiet you can get these squares. nite & day in my crew
dieseldawg142 is offline   Reply With Quote
Old 05-27-2014, 07:13 PM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Eastwood
http://www.classictrucks.com/tech/14...o_coustic_mat/
Malo83 is offline   Reply With Quote
Old 05-27-2014, 07:17 PM   #8
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I used FATMAT bulk pack, I ordered the 100sf, I did my truck then my brother-in-law did an S-10 and there was a lot left over.
http://www.fatmat.com/shop/fatmat-bulk-packs-6561
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 05-27-2014, 09:32 PM   #9
bigd65
bigd65's Avatar
lowes PEEL AND SEAL.... Cheaper than dynamat.... And does the same thing
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 05-27-2014, 10:49 PM   #10
badchevy
I think that's what I used too on my '82. I found mine in the air conditioning supply isle at Lowe's. Stuff is used to seal air conditioners and piping. It's almost the same as dynamat but a lot cheaper.
badchevy is offline   Reply With Quote
Old 05-28-2014, 04:06 AM   #11
Skunksmash
Skunksmash's Avatar
Just don't use asphalt based ones. Make sure its butyl rubber based.
Skunksmash is offline   Reply With Quote
Old 05-28-2014, 05:00 PM   #12
silverbear
silverbear's Avatar
I used Al's Liner H-N-R. It is a heat and noise reducer. It comes in a one gallon bucket for about $50 on Amazon, a little bit more at Advance auto. I rolled two coats on the floor, firewall and behind the seat and I only used about 20% of the bucket. It can be brushed or sprayed on also.
It does reduce the heat coming up through the floor and firewall. I can't speak about the sound reduction yet as I still have several open ports in the firewall and floor.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 05-28-2014, 05:10 PM   #13
silverbear
silverbear's Avatar
Picture of the HNR on the floor. Each coat was about 1/16'' thick.
1996 GMC Yukon GT
Old 05-29-2014, 08:49 AM   #14
Rich84
Rich84's Avatar
Got this from Summit..I think it was $50 a roll..
Rich84 is offline   Reply With Quote
Old 05-29-2014, 08:51 AM   #15
Orion88
Orion88's Avatar
Looks good. How much material did you use to cover that? And how many square feet are in one roll?
Old 05-29-2014, 08:57 AM   #16
Rich84
Rich84's Avatar
http://www.summitracing.com/parts/THE-14620/?rtype=10
I think used 3 rolls..
Old 06-07-2014, 02:29 PM   #17
John Gilbert
Attachment 1259816
That looks great, you did a clean job! Since the article in Classic Trucks I did, I used Eastwood Thermo-Coustic for an article in Street Rodder in my '27 roadster and its amazing what a difference it made. You wouldn't think doing an open car would be an improvement.
Somewhere on Custom Classic Trucks website there's an article archived using Dynamat on my '79 Squarebody.
John Gilbert is offline   Reply With Quote
Old 06-11-2014, 04:05 PM   #18
Skunksmash
Skunksmash's Avatar
"Bang" for your buck is something I've been wanting to know for a while now.
I have emailed a lot of the sound deadening sales people, and none of these companies are ever willing to do any testing. Like decibel tests. They are likely afraid to find out who's actually the best. A lot of it is down to the mil thickness of the aluminum though. A lot of these solutions I see on here, really aren't going to be very effective due to the very thin aluminum backing. Roofing supplies are going to have a very thin aluminum compared to those designed specifically to hamper sound. They're just not made for that purpose.
Then you need a layer of foam, then you need a layer of vinyl. So unfortunately there really isn't a cheap way out on this one.
Old 06-11-2014, 04:50 PM   #19
tylervalo
I used Lowes Peel and Seal for sound and another Lowes product for heat and sound insulation.
[/URL]
The Peel and Seal is basically just for resonance and little bit of a insulation, the other product is 2 layers of aluminum with bubble wrap in the middle, should be great at heat and sound insulation. Total cost about $50
tylervalo is offline   Reply With Quote
Old 06-11-2014, 05:49 PM   #20
Orion88
Orion88's Avatar
I bought 100 square feet of Fatmat Mega Mat. It's a true rubber butyl product and I should have enough leftover to do my 70 GTO as well. At $240 this was the best deal I could find. After I finish my GTO I will probably pull the seat and carpet and put in some closed cell foam and the mass loaded vinyl. That stuff is expensive!!!
Old 06-11-2014, 06:32 PM   #21
midnight rambler
midnight rambler's Avatar
i used the peel and seal under the seats and fat mat where the feet go so far no problems
midnight rambler is offline   Reply With Quote
Old 06-12-2014, 12:27 AM   #22
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Originally Posted by carboncrew View Post
i am happy with raamaudio product.
Their stuff seems really sticky (won't come off in az summers), good price, etc...
x2
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 08-31-2022, 01:03 PM   #23
smullen
I've been doing Car Audio systems for the better part of 30 years and have deadened and sound proofed several of the ones that had bigger systems.
I spend the time and money to do this this for a number of reasons.
1. Reduce resonate or panel vibration. I hate to hear a car drive by where it rattles to the beat, sounding like its going to fall apart.
2. Road Noise. I also hate trying to listen to a good SQ song like Hotel California or a good jazz song that has a lot of mids and highs, to show off that part of the system, but they appear to be washed out do to the road noise.
3. I like when I close a door, hood, trunk like or whatever, for it to have a solid Thump to it, not a thin almost a ringing sound from the thin metal vibrating...
With the 82 I got a few weeks ago, when I strip the interior, I think I'm going to use at least two different products.
1. A spray in, to coat the inside of the doors, fenders, bed bottom, under side of the cab floor, fire wall, etc..
2. Then a deadener sheet that you apply like a Dynamat product, but probably a brand called SecondSkin...
I want this thing deadend and quite except for the Stereo and a bit of the exhaust note and Sounds from the bag valves maybe...
Whatever I mount the compressors to will get deadeded for sure.
smullen is offline   Reply With Quote
Old 08-31-2022, 02:07 PM   #24
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i buy the stuff on amazon and it works well
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-01-2022, 01:54 PM   #25
Loco83
Loco83's Avatar
Kilmat.
https://www.amazon.com/Kilmat-Deaden.../dp/B0751G6TMV
Loco83 is offline   Reply With Quote
