Old 06-04-2014, 08:40 AM   #1
Skunksmash
Skunksmash's Avatar
Question Anyone know the exact height of the trim?
Truck is an 87 Silverado. I am putting new trim on my truck after having had it painted. I saved a little money not having the bodyman do a lot of stuff that I can do myself.
But I didn't consider one important detail. I dont know the exact height of the trim. With no old crusty lines from the old trim, I don't know how high up its supposed to be on the sides of the truck. To clarify, I'm talking about that rubber door guard stuff that runs the length of the truck, going all the way down the side.
Its this stuff, got it at Oriellys:
http://www.usa1industries.com/1981-8...t-longbed.html
Does anybody here have a factory truck that still has that trim on it? Or at least those grungy old lines where it used to be? If so could you possibly take a measurement from the bottom of the truck? Preferably right at the bottom of that lip where the steel rolls over the underside. That way I'll know to just measure from the bottom of that and it will be easier.
Or, if someone somehow has access to that information perhaps from a shop manual or reliable web source or something. Last thing I want to do is get it wrong.
Skunksmash is offline   Reply With Quote
Old 06-04-2014, 06:56 PM   #2
Project82
Bretzke Racing Inc.
Project82's Avatar
Re: Anyone know the exact height of the trim?
Hello, from what I remember where my trim/molding was before I peeled it off, it was dead center on the square fuel filler door on both of my bedsides, (dual tanks...if that helps any)
I would get some masking tape and start just under the rear tail lights and run that same piece of tape up to the side marker lights up front....should come out pretty close to the "center" of the fuel filler door...If not centered, maybe a hair below "center"
Wish I could help more with an exact measurement though!
Good luck!
Kris
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic
Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear)
2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic
Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12
"Expect the Un-expected"
"Gas, Grass, Or Ass...No one rides for FREE!"
Project82 is offline   Reply With Quote
Old 06-05-2014, 12:28 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
The side trim is lined up with the front marker light and at the rear it is centered under the taillight and the body line of the rear of the bedside. Run a a stripe of masking tape from the top of the marker light in front to the bottom of the rear taillight down the length of the body. Put your trim on the body below that tape line.
Here is a side shot showing where the trim is. I hope my explanation made sense..
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
