Old 07-01-2014, 12:42 PM   #1
KyleSeal
KyleSeal's Avatar
Removing Air Conditioning
I would like to remove the A/C from my 1970.
Does anyone know of a thread with photos to show how to? It doesn't have a compressor so it's virtually useless to me.
I've searched for a few days and no threads. So can you guys help me? Thanks.
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 07-01-2014, 01:24 PM   #2
trac209
Re: Removing Air Conditioning
I don't think too many guys would pluck out an ac system so you might be on you're own with this one. Personally I'd find a compressor and get it working.
trac209 is offline   Reply With Quote
Old 07-01-2014, 01:31 PM   #3
KyleSeal
KyleSeal's Avatar
Problem is that I'm doing a slam. The A/C will get in the way too much and honestly the last guy messed it up so bad it's barely even fixable. It'd be worth more to someone who can use the A/C, as I don't normally use it even on my DD.
Toano VA
Old 07-01-2014, 01:35 PM   #4
leftybass209
leftybass209's Avatar
I would agree with getting a compressor rather than removing, but to answer your question- start in the engine bay first. I don't mean to sound sarcastic or rude but it's simple mechanics if that makes sense. There's no tricks or gimmicks to removing. You will have to pull your hood and your inner fender to remove the box. Once you remove the engine bay components you will need to disconnect the cables and pull the defrost and ac hoses. Remove the ac glove box and remove the bolts for the inner box. You will be left with a gaping hole and no heat or defrost. The other option is to purchase an ac delete box which keeps your heater but loses the ac specific components.
leftybass209 is offline   Reply With Quote
Old 07-01-2014, 01:39 PM   #5
davepl
davepl's Avatar
I too say fix it (I don't know what a slam is). I guess you could sell the leftover parts.
Keep in mind that AC cabs are different. Not just the holes in the dash, I believe the firewall openings are very different for the AC box vs. standard Heater box. So you're likely going to have to keep the AC box anyway, which will look weird. Unless you're going to the point of reworking the metal on the firewall...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-01-2014, 01:43 PM   #6
KyleSeal
KyleSeal's Avatar
Slam as in suspension. Bagging the truck
Toano VA
Old 07-01-2014, 01:47 PM   #7
davepl
davepl's Avatar
Ah. So like when it's lowered it's so cool you don't need AC?
Old 07-01-2014, 01:50 PM   #8
KyleSeal
KyleSeal's Avatar
Lol, I'm a windows down guy. And the tire will end up hitting the box.
Toano VA
Old 07-01-2014, 02:33 PM   #9
tfi rcing
Pretty simple, just unbolt and remove everything from both sides of the firewall,fab up some plates to smooth the firewall,box everything up and send it to me...
tfi rcing is offline   Reply With Quote
1970 c10, a/c, air conditioning, cold air, vintage air
