#151 |
![]() Join Date: Mar 2013
Re: Randy & Jakes 64 4x4 SLOW build
Looking good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#152 |
Thanks GUYS, I had to order an oem rear cab mount, the one I had was slip on and it didn't fit worth a hoot. Ordered that and a couple of stickers one for the valve cover High Torque 292. The driver side cab corner is really not that bad just a couple of pin holes and the rear mount is solid so that side will be an easy fix. Hopefully tomorrow when I get off work I can help a gentlemen pull an engine for that mount I needed... After I get these corners knocked out I can go back and tidy up the rockers and some pinholes and some drilled out holes that PO just screwed sheet metal over the rust... I have to address some small holes on passenger side above windshield and some on inside of passenger side roof area above door, Then all that's left will be the doors as far as rust, which need bottoms and lower outers replaced, that oughta be fun.... I forgot about the front end need inner fenders and fenders, sounds like I need a whole new truck. Guess what I will be when I get done. can't wait cause I'm gonna drive the wheels off it... It's gonna be my daily driver....
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#153 |
First of all I really Saddened that my Favorite Actor has Died James(jimbo) Garner (Rockford). watched that show when I grew up in the 70's. still watch it on ME-TV.
anywho getting my corners worked in.. ![]() gotta wait til I get the floor support in b4 I can trim somemore... ![]()
#154 |
that 1st one looks pretty good. tack it in and that side should be good huh?
'62 Chevy K10 |
#155 |
Ok got my cam and lifters ordered, found me a good Battery on CL for 40 bucks only a 1yr
old cost new 120. Can't wait to change out the cam and lifters that's a part of engine that will be new to me...
#156 |
You running a stock cam? You know what would be cool...is to get a custom ground cam to stock specs and have the lobe separation changed...from the stock 114 to 110....make it sound a little crazier...then change to headers and dual exhaust...then it sound like a small block! LOL!
#157 |
I like how T.J. thinks.
#158 |
Yea afraid so T.J. If money wasn't sooooooooo tight then I would consider some of those options. Right now just trying to get it going as I still have lots to do just about need a whole new front end except hood. Yesterday when I got that new battery I tried to start it
in gear which is a bad thing cause I was standing in front of the front tire and when I cranked it over with a screw driver and it tried to run me over, thankfully it was out of gas and didn't start or could have been bad.. Always make sure double check to see if it's out of gear.... Had to buy me another grinder the other one finally bit the dust,, got to buy a gear/pulley puller, went to go see a guy about some front tow hooks but he wasn't home.. need more tools. Argh, Argh, Argh....
#159 |
Well I pulled out the Heart cam and lifters to and to my surprise all the lifters looked pretty good with normal wear except the rear in the back here's what it looked like..
![]() ![]() and here's the cam it's shows some wear but the rear lobe is almost gone...Thank fully my cam and lifters come in tomorrow... ![]() ![]()
#160 |
Yahoo, yahoo.yippy yippy,yippy, my cam and lifters are here, ye haw...
#161 |
Randy--I hate to say all that cam lobe metal is in your bearings
1961 chevy K10 my build is------------61K10 build |
#162 |
Argh!!! Kimble you didn't have to say that, But guess that metal had to go somewhere..
I got the new cam and lifters in now. I just have to clean up and paint the timing cover and the balancer and install. Get everything adjusted and fire it up.
#163 |
![]() Join Date: Aug 2008
Nah you're fine. Coming off the cam and lifters the oil is either going over the valves or splashing back into the pan where its getting pumped and filtered. Dont worry about it. Juat drive it.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#164 |
Randy--at least break in the cam correctly and use a break in additive. oil is not what it use to be.
#165 |
I used an assembly lube it's red in color and very sticky and I also dipped my lifters in oil b4 dropping them in and them poured more oil on top of them. But now it's raining here now and supposed to rain tomorrow so Don't know if I'll get to work on it..Rats, Rats, Rats
I did bake my timing gear @ 400 for 30 min, and drove it on with a piece of wood and hammer... as far as breaking in the cam, what does that really mean...
#166 |
You are supposed to run at a couple different RPMs for ashort sustained period of time. There are usually instructions with the cam and lifters.
#167 |
Instructions what's that LOL..... I do believe I remember seeing something in the box, I
will have a look see.. Despite the cam being worn the engine is very clean inside there's no gum or sludge build up whatsoever...
#168 | |
#169 |
Yeah! What he said!
#170 |
Thanks T.J. and Jason, Today the weather is cloudy and only going to be in the 70's so the weather will be perfect for doing that...I have to help with house cleaning b4 I can go out and play...
#171 |
some say to vary the rpm's 1500-2000 for at least 20 minutes and put this zzdp in your oil.
the break in is a must. all the pros say this. ran my new crate eng for 20m with break in oil. the cam basically gets oiled by splash-why the 2000rpm while break-in. Kimble
#172 |
Woo-Hoo she lives and runs again let her run for a good 15 min. she's oiling good and good oil pressure.. glad to get this part done, this was my first cam change and it went pretty good with YALLS help and books and youtube and google, and some general knowledge and some common sense... It rained all day last Sunday so I didn't get to get that motor bracket I needed so I can get rid of that Hammer LOL.. still on the hunt for powersteering Brackets. I got to make some calls I got a couple of leads, so there is still hope.... Once I get that done then it's back on sheetmetal... Slowly but surely you know Rome wasn't built in a day as they say..........
#173 |
I see yer logged in...yer supposed to be working on yer truck!
#174 |
T.J. I never log out.
#175 |
Ah see...being sneaky huh?
