Old 08-12-2014, 12:20 AM   #1
poco64
help with rear cab support
getting my but kicked trying to install a rear cab support, any tricks to this. also should i brace the cab before i remove it. thanks for the help.
poco64 is offline   Reply With Quote
Old 08-12-2014, 06:46 AM   #2
PGSigns
PGSigns's Avatar
Re: help with rear cab support
Should brace the cab before any floor surgery. At the minimum leave the doors on and shut.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-17-2014, 12:28 AM   #3
racecougar
racecougar's Avatar
What exactly is giving you trouble?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 08-19-2014, 08:41 AM   #4
poco64
I think most of the problem is an ill fitting reproduction. I have a wrecked donor cab with a good support in it. I am going to cut that out and try that. getting away from it for the weekend might also will help. I am also trying to do it with the cab on. wanted to restore the cab integrity before removing it. I cut the old one off about half way up and am trying to butt the new one to it. Installing all new rocker inner and outer and front lower pillar and cab corner
Old 08-19-2014, 09:11 AM   #5
racecougar
racecougar's Avatar
Ah, I went through much of the same. The repop rear cab supports I received required a fair amount of rework. I also installed them with the cab on the frame.
Starting here:
http://67-72chevytrucks.com/vboard/s...6&postcount=25
It all turned out well though, at least IMO.
Old 08-19-2014, 09:34 AM   #6
LT1 Burb
LT1 Burb's Avatar
Nice job, it looks good.
LT1 Burb is offline   Reply With Quote
Old 08-19-2014, 10:45 AM   #7
1963c-10
1963c-10's Avatar
Starting here:
Nice job. Noticed you didn't brace the cab....no issues there? I see some that do and some don't....
1964 Short bed trailer
Old 08-19-2014, 10:52 AM   #8
racecougar
racecougar's Avatar
Thanks guys. You'll see in my build thread that the cab was braced and panels were zip-screwed in place after setting the door gaps but prior to welding the floor panels and rockers. I tightened up the door gaps, particularly at the rear, a bit from stock.
