Old 07-31-2014, 08:32 PM   #51
clinebarger
Re: 700R4 build thread.
Forward Clutch detail.
Forward Apply plate (646).
Forward clutch waved plate (648).
Steel plates (649A)
Backing plate (650)
Forward Clutches (649B)
clinebarger is offline   Reply With Quote
Old 07-31-2014, 08:44 PM   #52
clinebarger
Overrun clutch detail, Not much to it.
Old 08-04-2014, 08:12 PM   #53
clinebarger
Now you will be looking at the Overrun/Forward piston Return spring assembly.
Compress spring cage, Remove snap ring.
Turn Drum over, Apply air to the 3-4 clutch feed (shown in earlier post).
This will blow the pistons out. Some builders smack the drum against the work bench to remove pistons, Good way to crack this delicate drum.
Remove the inner O-ring from the Input Drum (pic), DO NOT forget to reinstall this O-ring!!! Upon assembly. Thin Green O-ring in the seal kit.
Old 08-05-2014, 08:00 PM   #54
clinebarger
On to the Reverse Input Drum.
**NOTE** 82-86 used a different drum than 87-93, They DO NOT interchange!
The early one has a Steel piston The late drum has a Aluminum piston.
Remove snap ring, An Awl works best. Lift the clutches & steels out. Compress the return spring cage, Remove snap ring, Remove Piston.
I recommend replacing this drum, The 2-4 band rides here. If you want to reuse it Check it with a Straight Edge for flatness, If flat, Do a light cross hatch with emery cloth to knock the glaze off. Then Replace BOTH bushings!!
New drum for $62.11, Amazon.com: 700 4L60E New Reverse Input Drum:... Amazon.com: 700 4L60E New Reverse Input Drum:... Worth it if you ruin a few bushings getting your technique down.
Old 08-05-2014, 09:21 PM   #55
clinebarger
Front pump, Using the stand you made earlier out of the sunshell, Place the pump Seal down on the stand.
Remove the 5 13mm headed bolts that hold the pump halves together. Pull up on the top pump half exposing the Pump rotor, Vanes, Slide, Ring.
Remove the top Pump Ring, Lift the Pump rotor up by the torque converter lugs. Vanes will fall everywhere, Gather those up, Remove lower Pump Ring, If the plastic Rotor Pilot was left behind Remove it.
Fun Fact...The Rotor pilot's only purpose is to keep the Pump rotor centered for Torque Converter install.
Using a screwdriver or awl. Get under the primer spring & remove it.
**NOTE**Always use you hand to block springs from launching into orbit
Remove Pump Slider, Wiper seals, Slider pin & spring.
Inspect both pump halves for damage, Inspect for Pump Bushing walk.
Old 08-05-2014, 09:24 PM   #56
clinebarger
Continued,
Old 08-06-2014, 09:48 PM   #57
clinebarger
Parts ordering.
I highly recommend using 4L60E frictions in ALL '87-'93 700R4's, Along with late "E" molded pistons in the Input Drum.
This is an "E" kit with Borg Warner frictions (Hi-Energy 3-4 clutches & 2/4 Band), Raybestos steels, Teflon pump bushing, Case bushing & molded pistons Amazon.com: 4L60E 4L65E 4L60-E Master Overhaul... Amazon.com: 4L60E 4L65E 4L60-E Master Overhaul...The Filter & Valve body gaskets WILL NOT work on 700R4's, But at $172 the filter & seal kit are free. And its good for a first timer to have extra seals
700R4 seal kit, TransTec has the Lip Wizard Lip seal tool included.
700R4 Filter, SPX-Filtran
4L60E Overrun return spring assembly, GM part# 4206085, Needed for molded pistons.
Borg Warner 29 element Forward Sprag
Borg Warner Low/Reverse Sprag
Sonnax pinless accumulator pistons (2) http://www.sonnax.com/parts/2520
Sonnax purple accumulator springs (2) http://www.sonnax.com/parts/1660
TransGo SK 700-JR, Their TV kit is top notch. Good accumulator bushing spring selection as well. The rest of the kit does not work well in all transmissions!
TransGo Pump Rings
New pump Vanes
TransGo 700-p separator plate
Sonnax wide sun gear bushing
Sonnax wide Stator bushings
GM 3-4 apply plate, Part# given earlier
Torrington/Koyo bearing kit
Old 08-07-2014, 08:07 PM   #58
clinebarger
ASSEMBLY.
If you did not install Case Bushing already, Do it now.
Install the transmission (low and reverse clutch outer, center, inner) seals (696) on the low and reverse clutch piston (695).
Lubricate the seals with Transjel or an equivalent.
Install the low and reverse clutch piston (695) into the case. The notch in the piston must be aligned with the parking brake pawl window, in the case.
Install the low and reverse clutch spring assembly (694).
Using the J23327-1 or similar tool, compress the low and reverse clutch spring assembly (694).
Install the low and reverse clutch retainer ring (693).
I don't use snap ring pliers on this snap ring, Using 2 long flat screwdrivers. Start one end of the snap ring in the groove using 1 of the screwdrivers, hold it in the groove, Use the other screwdriver to roll the rest of the snap ring in.
Old 08-07-2014, 10:58 PM   #59
clinebarger
Reaction carrier is next, Soak the Reaction to Case Torrington Bearing it ATF for a few seconds, Put 2 small dabs of transgel where the Torrington sits on the Carrier, This will hold the bearing in place. Lube the case bushing will a light coat of Transjel.
Install the Carrier in the Case, Give it a good whirl, It should spin very freely in the case.
If the carrier is hard to turn, Take a Hammer, Grab it by the Head, Lightly hit the carrier with the Handle on the red circles in an alternating pattern, This will seat the Case Bushing.
Old 08-07-2014, 11:08 PM   #60
clinebarger
Pictures...
Old 08-08-2014, 08:09 PM   #61
clinebarger
Time for the Reaction Planet, Soak The Torrington bearing in ATF, 2 dabs of transjel to hold the bearing, Roll the Planet through the ATF lubing the Pinions & internal bearing.
Install Planet into Carrier, Insert your Index & Middle finger through the center of the Planet while installing.
Put a dab of Tranjel on the Case where the Anti Clunk spring goes, Install spring as shown in the pic.
**NOTE** Soak all Frictions for at least 30 min. before installing!
Lightly sand all steels plates where they meet a Friction, Don't go crazy, This is just a surface prep. Wash steels afterward!
Install the Low/Reverse Wave Plate with the Notched tab at the 6 0'clock position.
Steel plate next.
Then a Friction.
Keep alternating Steel-Friction 'till you run out, 5 Frictions in the Low/Reverse clutch, When done you should be staring at a Friction NOT a Steel!
Old 08-08-2014, 08:55 PM   #62
clinebarger
Up next is the Center Support.
Install New Low/Reverse Sprag, Install Inner Race.
Look at Center Support, There is a notch that's wider than the rest, Match it to the wide Lug in the Case.
Sit the Center Support down in the Case, Rotate the Low/Reverse sprag race 'till lined up.
Use a Hammer Handle to seat the Support to the Case.
Inspect the Anti Clunk spring (see pic)
Install Snap Ring, The White marks are where the ends need to be.
Old 08-09-2014, 07:52 PM   #63
clinebarger
Reaction Sun Gear Mods.
Grind 4 small notches in the Face of the Sun Gear that rides on the Reaction Planet internal bearing.
This improves oiling to the bearing & Planet.
Replace the Bushing with a Wide Sonnax bushing, In the old day's we doubled the stock bushing.
This adds stability to the Input Planet, Reaction Tube & Sunshell.
Install Sun Gear into the Planet.
Old 08-10-2014, 07:34 PM   #64
clinebarger
**If using a stock Sunshell, Place the 4 Tanged plastic Thrust Washer on the Low/Reverse Sprag Race. Insert sunshell into the Reaction Sun Gear splines.
**If using a Beast Sunshell, Leave this Thrust Washer out, Use the Plastic Thrust washer supplied with the sunshell, Use 2 dads of transjel to stick it to the bottom of the shell. Insert sunshell into the Reaction Sun Gear splines. This Sunshell is VERY popular, I decided to include it.
**If Using a Sonnax Smart-Shell, Leave the stock thrust washer out, Soak the Torrington bearing that comes with the Shell in ATF, 2 dabs of Transjel to stick it to the bottom of the shell, Insert sunshell into the Reaction Sun Gear splines.
Old 08-10-2014, 10:21 PM   #65
BADAZ chevy guy
BADAZ chevy guy's Avatar
Of the three, which Sunshell would you recommend?
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 08-11-2014, 05:55 PM   #66
truckdude239
truckdude239's Avatar
Sonnax Smart-Shell ive read the beast sun shells sometimes have problems
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 08-11-2014, 07:55 PM   #67
clinebarger
As David said, The Beast have certain issues, Not being balanced being the biggest issue, The heavy weight amplifies it, I have also seen some that are not True. Many Builder swear by them because they don't break.....But what's the point if it's going to beat the Bushings out.
The Stock Delco Sunshell is Fine for under 350 ft/lbs, It was updated a few times & alot better than they used to be (Softer material to prevent breakage), The stuff you read on the internet is from problems 20 years ago.
The Delco shell has 1 Achilles Heel, The Splines can Strip if to much torque is applied. Or towing heavy through hilly terrain....Constant 2-3, 3-2, 2-3, 3-2 can wear the splines, But other things wear as well under these conditions, The pic is a 3-4 clutch plate from a 4.8L/4L60E truck that tows through Colorado a lot, I rebuilt it about 60,000 miles ago, The Sunshell stripped, But look at the internal tangs on the Clutch plate....Almost worn off!!
Point is the Stock shell will last as long as the rest of the Trans IF not over torqued.
The Sonnax Sunshell is actually a reinforced stock shell, A plate is welded around the splined to stop deformation, The reverse input drive lugs are heat treated. A Torrington bearing is added to keep thrust load off the Reaction Planet Torrington. This is a very nice piece, & if funds allow....Highly recommended.
Old 08-12-2014, 07:39 PM   #68
clinebarger
OK, Your trans should look like this, Ready for the Reaction Tube/Shaft, & 3-4 Clutch Hub/Input Planet Annulus gear.
Old 08-12-2014, 08:00 PM   #69
clinebarger
**If your reusing the Reaction shaft (with a Flat bottom), Place the Brass 4 tang thrust washer on the SunShell, Use TransJel to stick it to the Shell.
**If using an Updated 4L60E Reaction Shaft, Soak the Torrington in ATF, Stick the bearing to the Reaction Shaft......The Delco Shell kit comes with a Shell, Shell to reaction shaft Torrington bearing, Reaction Shaft, & Input planet to reaction shaft Torrington bearing.
**If you are using a Beast or Sonnax Shell, You can still "rollerize" the Reaction Shaft, You need a Reaction Shaft & BOTH Torrington bearings from GM.
**NOTE** DO NOT use the Input Planet to Reaction Shaft Torrington from the bearing kit if you get a Reaction Shaft from GM, It was revised in '07/'08.
Old 08-13-2014, 07:33 PM   #70
clinebarger
Install Reaction Shaft/3-4 hub assembly.
Soak Input Planet in ATF, Soak input planet to reaction shaft Torrington bearing in ATF,
Stick the bearing to the bottom of the planet with TransJel.
Install Input Planet into 3-4 Clutch Hub.
Old 08-13-2014, 07:46 PM   #71
clinebarger
Using an air blower, Check all Lube holes in the Output shaft for blockage.
Insert Output shaft from the bottom of the unit, Turn it to engage everything, Use a Bungee cord to hold the shaft in place while installing the snap ring. Use the New snap ring included in the rebuild kit!
The Gear train is now done.
Old 08-14-2014, 08:30 PM   #72
clinebarger
If your Input Sun Gear is separate from the forward sprag. Place it in the Input planetary.
700R4's had separate Sun Gears from the factory, Just being thorough, Ive opened quite a few that had 4L60E forward sprags.
Old 08-14-2014, 09:24 PM   #73
clinebarger
Cover the Case/Geartrain with something lint free, Like a old bed sheet.
Time to build Drums....
Lets start with the Forward Sprag assembly, DO NOT use '82-'86 Forward Sprag assemblies!!
ID info....The early sprag assembly. Has no thrust plate & requires a plastic thrust washer on top of the Input Planet, The Late Sprag has a Thust Washer.
Old 08-15-2014, 08:26 PM   #74
clinebarger
Place Sprag assembly on the work bench with the Overrun hub facing up, Remove snap ring, Remove Overrun hub.
Separate the Forward clutch hub from the Sprag, Remove Sprag & both Sprag retainer rings & Discard.
**NOTE, Use Borg Warner Sprags, If it does not say Borg Warner on the Package...It's a Knock off...DO NOT use. If a genuine BW cannot be found, Go to the Dealer & buy a SKF Sprag, In fact a SKF is fine behind a stock engine.**
Note the position of the "Dogs" in the pic for reassembly.
Install 1 of the Sprag retainer rings on the Inner Sprag Race.
Install the Sprag Element in the Forward Clutch Hub (outer race).
Roll the Inner Sprag race into the Sprag element.
Temporarily place Overrun hub on Inner Race, Hold Forward Clutch Hub still, Overrun Hub should turn Clockwise, But not Counterclockwise. If the Overrun hub turns Counterclockwise....The Sprag is installed backwards, Correct before proceeding!!!
Remove Overrun Clutch Hub, While holding the assembly together, Dip it in ATF.
Install the 2nd Retainer Ring, Install Overrun Clutch Hub, Install snap ring.
Old 08-15-2014, 09:23 PM   #75
clinebarger
Time to build the Input Drum.
Install the Inner "Green" O-ring in the Drum, Refer to post #53. Lube O-ring with TransJel,
Install 3-4 Piston, Lube both Lip seals with TransJel, Start the piston lip seal at an angle in the Drum & Rock the Piston into the Drum, No Lip Seal tools required for this piston.
USE ONLY 4L60E Molded steel 3-4 Piston!! The Stock aluminum piston is known for porosity problems & cracking.
