Old 09-21-2014, 03:15 PM   #1
cameyer
hydraulic clutch for 64
Just wondering if anyone has swap in a hydraulic clutch setup for a 64-66. I know there is a kit for the 60-62 but what about the later years? I am not interested in running a power brake booster but would like to up grade to a dual reservoir master cylinder from a later year truck. Anyone have any ideas?
cameyer is offline   Reply With Quote
Old 09-21-2014, 08:20 PM   #2
AcampoDave
AcampoDave's Avatar
Re: hydraulic clutch for 64
I'm a bit confused by your question as a '63-'66 comes factory with a mechanical clutch. Are you wanting to convert from mechanical to hydraulic?
AcampoDave is offline   Reply With Quote
Old 09-21-2014, 09:28 PM   #3
cameyer
Yes exactly I'm looking to put in a hydraulic clutch. In place of the mechanical set up. Here is basically my plan. I have a 64 k10 and plan on swapping a 14 bolt rear in and a dana 60 with disk brakes front and putting in a dual reservoir master cylinder for the brakes and hope to get a hydraulic clutch as well
Old 09-21-2014, 09:53 PM   #4
jtrichard
Take a look at this its what you need i belive http://www.67-72chevytrucks.com/vboa...d.php?t=362375
jtrichard is offline   Reply With Quote
Old 09-21-2014, 10:18 PM   #5
HumphreyMurdoch
HumphreyMurdoch's Avatar
I don't know if that would work on you're '64, I could be wrong.
Another option is the Novak kit, takes some modifications to the cast iron bellhousings but can easily be done.
http://www.novak-adapt.com/catalog/clutch/kit_hcr3.htm
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
Old 09-21-2014, 11:07 PM   #6
cameyer
Thanks for the info guys. I've seen that captin fab one before but don't plan on running a brake booster so I don't know if that would work very well. Looks like that Novak one may be the way to go. Then just have to figure out a master cylinder to work with it
Old 09-21-2014, 11:43 PM   #7
jtrichard
you would not need to get the bracket for the booster just the clutch parts
Old 09-22-2014, 01:03 AM   #8
Captainfab
60-66 Nut
I do make a booster bracket with a hydraulic clutch conversion for the '63-'66's. I just don't have a for sale thread yet. But since you don't want a brake booster, I could sell you just the linkage assembly for the clutch master.
Old 09-22-2014, 09:19 AM   #9
wayno
Captain-
I'd also be interested in your linkage assembly - can you pm me a quote?
-W
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 09-22-2014, 11:46 PM   #10
Captainfab
60-66 Nut
The '63-'66 booster bracket with hydraulic clutch conversion is basically the same as what I make for the '60-'62's, including the price. The current linkage can be seen in post #44 in the for sale thread:
As for purchasing the linkage separately, I will have to do some figuring to see what that cost will be.
Originally Posted by wayno View Post
Captain-
-W
Old 09-23-2014, 01:26 AM   #11
argonaut
argonaut's Avatar
Here are a couple pics of how I did mine. In the end I picked up a hydraulic bellhousing but when I switch to the NV4500 I may fabricate another slave cylinder mount similar to this one.
http://67-72chevytrucks.com/vboard/s...&postcount=156
http://67-72chevytrucks.com/vboard/s...&postcount=193
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-23-2014, 01:44 AM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
That's a slick setup.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-24-2014, 02:44 PM   #13
wayno
Thanks Captain - I appreciate the consideration.
-W
