Old 10-01-2014, 09:51 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
Alternator mounting bracket question
Hey guys, long time no see
I'm replacing a cs130 alternator with a 12si for a friend And I quickly noticed that the mounting tabs are different.
The mount is cast aluminum and on the top left of the motor running serpentine. Has anybody jimmied a cs130 bracket to accommodate a 12 si? Is there something that can easily be bought?
Will the serp pulley fit on the 12 si???
Oh, it's on a crate 383 stroker.
Thanks,
Spencer
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 10-01-2014, 10:06 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Alternator mounting bracket question
Wouldn't that be a downgrade?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-02-2014, 12:54 AM   #3
willett
willett's Avatar
It's a high capacity 12si (140 amp) that were putting in and it's actually in a big 4x4 jeep YJ so were after the simplicity of a 1 wire setup.
I posted in this section because this is the only part of the site that I browse in and it's all Chevy under the hood
Old 10-02-2014, 02:29 AM   #4
Just call me Sean
Maybe someone else will know, but I would have to see it to figure it out. I put two 100 amp cs130s on my van, only cost me $25. Well, the second one cost $25.
Old 10-02-2014, 09:46 AM   #5
jetmech85
I am not very familiar with serpentine setups. Does your existing CS have mounting bolts at the 6 and 12 o'clock position like the 12SI alternator? I assume it does not and that is the problem you are having?
jetmech85 is offline   Reply With Quote
Old 10-02-2014, 12:54 PM   #6
gmachinz
You need to either make a heim ended bracket or go with an 88 Olds Firenza 105A alternator. Or, go with a serpentine setup....much more options there.
gmachinz is offline   Reply With Quote
Old 10-02-2014, 11:12 PM   #7
willett
willett's Avatar
I ended up wiring in the cs.
I also learned a lesson: don't run a cs without the harness plugged in. Voltage regulator doesn't appreciate it much.
Old 10-03-2014, 12:31 AM   #8
Just call me Sean
What harness? Mine have two wires each. One is the charge wire the other turns the alternator on.
Old 10-03-2014, 01:09 AM   #9
willett
willett's Avatar
The 2 wire "harness"
When we got the jeep it only had an ignition signal wire with no resistor (bulb)
I cut tht wire last night after attempting to install the 12si and didn't bother reconnecting it. Drove it for 5 mins to get down to the shop and by the time it got here the cs with no signal or sensing wire was charging between 16 and 19v
