Old 10-08-2014, 07:59 AM   #51
FarmerSid
FarmerSid's Avatar
Re: 54 Chevy Truck.... left to die
Ok. See it now. Are you going to leave it and add filler to even it out? If it were me and seeing that I recently had to do it, I would cut the panel in the area that is sunk it in the door opening area and pull it out. You have to do this with the door on to make sure you get things nice and flush. It's also easy to get in behind and use a copper backer when welding.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 10-08-2014, 07:55 PM   #52
sparks54
sparks54's Avatar
I am going to try and work it again soon after I cut off other cab corner and replace it. I have a little metal on the bottom rear of cab to replace also, so I will be welding close to the drivers side corner. I will be trying to blend it all together.
QUARTER TURN BEFORE IT SNAPS.....
1954 Chevy Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=584702
sparks54 is offline   Reply With Quote
Old 10-08-2014, 08:32 PM   #53
sparks54
sparks54's Avatar
1954 Chevy Truck
Old 10-08-2014, 08:36 PM   #54
sparks54
sparks54's Avatar
1954 Chevy Truck
Old 10-08-2014, 08:39 PM   #55
sparks54
sparks54's Avatar
1954 Chevy Truck
Old 10-08-2014, 08:40 PM   #56
sparks54
sparks54's Avatar
1954 Chevy Truck
Old 10-08-2014, 08:41 PM   #57
sparks54
sparks54's Avatar
1954 Chevy Truck
Old 10-11-2014, 06:31 PM   #58
sparks54
sparks54's Avatar
1954 Chevy Truck
