Old 06-14-2013, 06:40 PM   #1
sparks54
sparks54's Avatar
54 Chevy Truck.... left to die
I just was able to start on something I have been wanting to do for many years. I start to rebuild a 54 Chevy truck that was removed from the deep woods a little while back. I have loved these old trucks for years and now was my chance. It is a big job and one that will not be easy and one that will be slow but I so want to try. It might not be a show truck when I am done but I will try my best to give this truck a new life. Name:  re1.jpg
QUARTER TURN BEFORE IT SNAPS.....
1954 Chevy Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=584702
sparks54 is offline   Reply With Quote
Old 06-14-2013, 06:43 PM   #2
sparks54
sparks54's Avatar
Re: 54 Chevy Truck.... left to die
1954 Chevy Truck
Old 06-14-2013, 06:47 PM   #3
sparks54
sparks54's Avatar
I end up getting a 1990 Sonoma for the chassis.
1954 Chevy Truck
Old 06-14-2013, 06:54 PM   #4
sparks54
sparks54's Avatar
I have been spending most of my free time trying to clean up the frame and work on the suspension.
1954 Chevy Truck
Old 06-14-2013, 06:55 PM   #5
sparks54
sparks54's Avatar
1954 Chevy Truck
Old 06-14-2013, 07:32 PM   #6
Trekster
Trekster's Avatar
Wow, you have been busy. Good Job!
Trekster is offline   Reply With Quote
Old 06-14-2013, 07:47 PM   #7
Daze57
Daze57's Avatar
Good lookin project -good luck.
Love the story that you pulled it out of the deep woods
Daze57 is offline   Reply With Quote
Old 06-14-2013, 09:13 PM   #8
Denee007
Denee007's Avatar
Welcome, and my you work quickly!!
Dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 06-14-2013, 10:40 PM   #9
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by sparks54 View Post
.... It is a big job and one that will not be easy and one that will be slow but I so want to try. It might not be a show truck when I am done but I will try my best to give this truck a new life. Attachment 1120320
"This is my truck. There are many like it but this one is mine..."
Ha ha, something about the cadence of how you wrote your post really reminded me of the Rifleman's Code.
Welcome and glad to hear you're so dedicated to its resurrection. Keep the photos coming!
Dan in Pasadena is offline   Reply With Quote
Old 06-14-2013, 10:40 PM   #10
Truck Guy99
That's sweet? What's the plan for it?
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 06-14-2013, 11:21 PM   #11
wood1
That's a pretty rare factory clock... Looks like a nice start.
wood1 is offline   Reply With Quote
Old 06-15-2013, 12:04 AM   #12
Leroy-B1
I want the clock....looking forward to it I have a 55 first series that I need to do build thread on
Leroy-B1 is offline   Reply With Quote
Old 06-15-2013, 10:21 AM   #13
sparks54
sparks54's Avatar
Thanks everbody for your comments. Had a couple things show up yesterday that UPS had dropped off. Ball Joints, Tie Rod ends, Control Arms, also already have drop spindles and drop blocks for the back springs. I am going to try to keep track of everything I do on this project. More pictures to come soon.....
1954 Chevy Truck
Old 06-15-2013, 02:50 PM   #14
booger1949
love the project an yes i want the clock as well, wonder where u could find one of those at, an good luck on your truck an have fun
booger1949 is offline   Reply With Quote
Old 06-15-2013, 06:03 PM   #15
sparks54
sparks54's Avatar
Yes I like the clock also. You do not see alot of trucks that have them, it was a add-on feature in 1954. The old clock still worked when I pulled it out of the housing.
1954 Chevy Truck
Old 06-15-2013, 06:10 PM   #16
sparks54
sparks54's Avatar
2 inch drop spindles and drop blocks....
Just got the blocks installed
1954 Chevy Truck
Old 07-12-2013, 09:32 PM   #17
sparks54
sparks54's Avatar
Drop spindles all installed. While the front suspension was all apart I end up putting new ball joints, tie rod ends, and a new idler arm. I also removed one coil from the coil springs... I am planning on bagging the truck at a later time.
1954 Chevy Truck
Old 07-13-2013, 04:27 PM   #18
chevyboy73
chevyboy73's Avatar
looks like you mean business! 54 and 55.1 chevys are slowly become my favorite AD truck! keep on truckin!
2011 Silverado ECSB LT
2000 Silverado RCSB 2WD
super bad habit of not owning a vehicle for a long time
chevyboy73 is offline   Reply With Quote
Old 07-13-2013, 04:40 PM   #19
Dan in Pasadena
Excellent work so far! What's the story on the frame paint? Did YOU spray it, have it done by a shop, rattle can? If so, what brand, etc. Enquiring minds (nosy people!) want to know.
Old 07-13-2013, 08:25 PM   #20
Clay54
Good start - I will be watching. I have a clockless 54 that I will be starting shortly. Help me understand the configuration of the front cab mounts in the above pic. Most are on the outside of the frame. Thanks, Clay
Clay54 is offline   Reply With Quote
Old 07-13-2013, 11:36 PM   #21
sparks54
sparks54's Avatar
Clay54...... I made the cab mounts to fit on the outside of the frame at first. I end up moving the front mounts to the inside cause I believe that it would have been a much tighter fit if I would have left them on the outside of the frame when I try to mount the cab down. I am replacing all the floor in the cab with new sheet metal not the replacement pans and I am making a support frame under the floor. My floor support frame and cab mounts will hopefully work the way I plan for them to. ( fingers crossed)
1954 Chevy Truck
Old 07-13-2013, 11:44 PM   #22
sparks54
sparks54's Avatar
Sorry Dan I did not see your post about the paint. I took the frame down to raw metal and putting primer and a basic PPG silver that I am spraying with a small paint gun.
1954 Chevy Truck
Old 07-14-2013, 05:54 AM   #23
av8tr33337
av8tr33337's Avatar
Great start. I'll be following this one!
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 07-14-2013, 08:40 AM   #24
pvienneau
pvienneau's Avatar
Looks sweet so far.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Old 08-20-2013, 10:49 PM   #25
sparks54
sparks54's Avatar
1954 Chevy Truck
