10-19-2014, 01:47 AM | #76 |
Re: One Year Only Stuff 67-72...
People say the 67 seat folds forward but mine does not (unless maybe ifyou remove the bolts). Is it only buddy buckets that fold.?
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
10-19-2014, 03:01 AM | #77 |
02-18-2015, 03:13 AM | #78 | |
I don't know why it wasn't a more popular option... I really like the color. Its way better than that lighter blue that's for sure. |
12-29-2015, 05:33 PM | #79 |
I don't think anyone mentioned the vertical "bars" in the 1970 grill insert. I think there are 5. Not sure how this was accomplished but I would guess they painted the insert except for the darker "bars". The '69 grill insert was a solid color. I think the insert in mine is a repop but the area that should be darker is inset about a 1/32". My brother bought a new '69 and a couple months later I bought a new '70. Parked side by side the difference was quite noticeable. I drove a lot of miles with him in my rear view mirror. I'd be interested to see some pictures and to hear how guys have accomplished this.
12-30-2015, 09:21 AM | #80 |
Here is 1970 brochure showing the 5 vertical "bars" in the grill.
12-30-2015, 10:38 AM | #81 |
Fiewall indentation near heater box. Unsure if this was mentioned.
12-30-2015, 11:44 AM | #82 |
67 lighter
67 tac harness 67 key bezel 67 park/signal lites 67 manifolds,carry over? 67 bellhouseing/3 spd trans(small hole)carryover how bout the road draft tube? i know that is a carry over. 72 door panels 72 window regulators 71 front brake hose 72 front break hose alt brackets are differnt for most of the differnt years as is cruz controls
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
12-30-2015, 12:39 PM | #83 |
'68 big block power steering reservoir bracket (where it attaches to the fender)
'67/68 4 barrel air cleaner is different than 69-72, no heat riser tube coming from exhaust manifold Last edited by Eagle9502; 07-13-2016 at 10:13 PM. |
12-30-2015, 03:11 PM | #84 |
Wanted to add that side marker lights were optional in '69 also. My '69 C10 had reflectors my '69 C20 had the market lights.
12-30-2015, 07:46 PM | #85 |
The '68 CST two tone bench seat is unique to 68's. 67 CSTs were all buddy buckets. Buddy buckets were optional for 68 CSTS. I think the top of the line bench seat design changed in 69.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
01-25-2024, 03:30 PM | #86 |
I know that this is an old thread, but 1967 was the 1st year that the transfercase in 4WD trucks was married to the transmission and was the only year that the SM420 was married to the Rockwell T-221. 1968 saw the adoption of the SM465 married to the T-221. I believe that combination was available until sometime in 1969 when the NP205 transfercase was introduced.
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
01-25-2024, 05:26 PM | #87 |
Born Psycho
I didn't see 70 4x4s were a one year only front differential- open knuckle with drum brakes. 69 and older were closed knuckle drum and 71 and newer were disc.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
01-25-2024, 06:41 PM | #88 |
Used to be that the interior color on all chevy trucks was that silvery "champagne" color. Regardless of the exterior paint scheme. When did that end? My 67 c30 was painted that way.
01-25-2024, 07:51 PM | #89 |
1969 two tone color bucket seats.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
01-25-2024, 09:36 PM | #90 |
71 only year with raised pad for rear view mirror and only year for disc brake sticker on tailgate. 72 only year for vent window screw and plastic door panels
01-26-2024, 12:00 PM | #91 |
Another 2 year one many miss - Top of the windsheild area of the outside of the roof is recessed 67-68 , smooth 69-72
01-26-2024, 11:09 PM | #92 | |
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
01-27-2024, 02:44 PM | #93 |
01-28-2024, 02:59 AM | #94 |
The 67-68 windsheild opening has a 1/2 inch recess for the rubber all the way around , in 69 it just kinda disappears goin up the A pillar. No pics , I'm not that smart .... or I would have figured it out before I put a 70 roof on my 68 ... LOL
06-05-2024, 01:02 AM | #95 |
Not only were the 67 visor hooks different (the screw did not thread into the metal it split 2 plastic tabs to hold it in place) the hooks were mounted with the opening downward in 67 and 68 up they were upward.
06-05-2024, 07:17 AM | #96 |
This is partially true. This applies to K10 trucks. The 1969 K/5 Blazers had open knuckle drum brake D44 front axles.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
06-05-2024, 07:25 AM | #97 |
1970 only TCS relay mounted to the firewall by the heater box. The relay itself had two different styles, but they functioned the same.
One style: The other:
06-07-2024, 06:38 PM | #98 | |
The interior of my '67 K/10 Suburban is totally Fawn with a White exterior. My '68 C/10 Stepside has an Orange [516] interior and exterior, but with Fawn notes: Steel door panels, and Steering column and 3-spoke Wheel painted in Fawn. Matching Fawn synthetics: Vinyl seat cover, Seat belts, Sun visors, Visor hooks, vinyl Dash pad. Both trucks are from Fremont. CA. So they had a little Fawn left in the 1968 Model Year, and they used it up on contrast trim.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 06-07-2024 at 06:45 PM. |
