Old 10-28-2014, 08:11 PM   #1
Chevyc10572
Chevyc10572's Avatar
gauge cluster problem
My 89 gmc gauge cluster lights are out how hard is it to replace the bulbs
1970 chevy short box c10 factory 402 big block with AC
2008 chevy silverado regular cab short bed lowered
1990 454ss 52,000 miles 5/6 drop
Chevyc10572 is offline   Reply With Quote
Old 11-05-2014, 11:03 AM   #2
mountie
mountie's Avatar
Re: gauge cluster problem
Are all lights out? ( would be a connection problem)
If many are out, you can remove plastic frame around cluster, remove screws holding gauge cluster, lower steering wheel, and pull out .
The gauge cluster is only plugged in at rear, just pull out. ( you will see after removing )
Put cluster , face down & start removing screws, each board- layer at a time.
Look for a couple little harness connections between boards.
Eventually you will have all bulbs exposed.
( I did it & it wasn't tough to do )
Bulbs are at auto part stores... maybe have to go to a couple stores to get all the bulbs. ( they only stock a few per store)
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 11-05-2014, 03:51 PM   #3
Angryman117
If all the lights are out, it sounds like a connection problem. Also check the Instrument Panel Dimmer Switch, I had to replace mine.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
