#151 |
Re: Owen's C10
....threw down a layer of rage gold, and sanded till I found them. then I sealed it up with two coats of epoxy.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#152 |
![]() Join Date: Dec 2006
Re: Owen's C10
Looks good
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#153 |
Re: Owen's C10
#154 |
Re: Owen's C10
Looking good.
Dwight |
#155 |
Re: Owen's C10
#156 |
Re: Owen's C10
messin' around...
#157 |
Re: Owen's C10
...this morning I went to look at a motor, and ended up buying it....02 5.3l with supposedly 177k. I forked out $450 and brought 'er home, stripped it down and cleaned it up some..
#158 |
![]() Join Date: Nov 2013
Re: Owen's C10
Nice find on the motor.
#159 |
Re: Owen's C10
Very cool project and beautiful work!
Jealous of your welding skills ... I'm about 25% welder and 75% grinder :-) Will be a huge wow factor when you're done. Guess we can both safely say that Bill's in Oshawa is our saviour! |
#160 |
Re: Owen's C10
I like how you made the front frame rails match. It looks great. I plan on doing the same to mine.
#161 | |
Re: Owen's C10
thanks
I saw it done on another thread and couldn't help but do it too. I think it cleans it up a lot...
#162 |
Re: Owen's C10
shaved cowl..
#163 |
Re: Owen's C10
Wow nice job on the cowl
#164 |
Re: Owen's C10
#165 |
Re: Owen's C10
removed the manual steering box, linkage, and sway bar...(I put the sway bar on the '69) and got the front cross member unbolted and ready to come out....I'm going to be using a PB drop member
#166 |
Re: Owen's C10
removed the steering box mounts...
#167 |
Re: Owen's C10
....cut the rivets for the rad support mounts, and made some 3/16 plates. I'm going to make a tubular cross member that bolts on with the mounts.
#168 |
Re: Owen's C10
Fantastic work! I love the attention to detail.
#169 |
Re: Owen's C10
#170 |
Still Learning
Re: Owen's C10
Killer work on the frame, dash and cowl! Looks great....
Nice score one the 5.3 too |
#171 |
Re: Owen's C10
thanks.
#172 |
Re: Owen's C10
I've been super bored lately with the holidays, so I spent some time in the shop getting caught up on some things that were bugging me....pancaked the front cross member...cause I always wanted to try it, and I finished the other front cross member, and shaved the hole in the firewall where the wiring went through....
#173 |
Re: Owen's C10
What thickness metal did you use for the frame work? I tried to use some left over crossmember metal but it was a different thickness so I'll have to buy some.
#174 |
Re: Owen's C10
I think it was 3/16"....it was a bit thicker but I kept the top flush and ground most of it down...
#175 |
Re: Owen's C10
I picked up some '68 front fenders cheap, that some body hacked some Camaro vents into the side of, so I made a quick patch, and slapped some bondo on 'em quick to hide that mess....not sure if I will use these, but they work good enough for mock up...
