Old 12-02-2014, 11:02 PM   #1
trkfrk
trkfrk's Avatar
LS fuel system question need help
My LS1 is out of a 1999 Trans Am and has a return fuel system. I plan on using the corvette filter with built in PSI regulator to return back to the tank from the filter. My question is, what do I need to change on my fuel rail to get rid of the return line? Or do I need different fuel rails? If you have any part numbers that will be very helpful.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 12-02-2014, 11:12 PM   #2
trkfrk
trkfrk's Avatar
Re: LS fuel system question need help
Here is a pic of the filter
Mark
Old 12-03-2014, 03:50 AM   #3
ls1nova71
ls1nova71's Avatar
Only '97 and '98 Corvettes have return style fuel rails. What you have is a returnless. You dont need to do anything to it. The second lne is an evap line, you won't need it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-03-2014, 09:35 AM   #4
faribran
Good call Eric. This is the same set up I have.
faribran is offline   Reply With Quote
Old 12-03-2014, 10:55 AM   #5
trkfrk
trkfrk's Avatar
That's great news. What do you recommend I do with the evap line? Thanks for your help.
Mark
Old 12-03-2014, 09:25 PM   #6
trkfrk
trkfrk's Avatar
It looks like I can cap the fitting coming out of the manifold for the evap hose. Has any one done this?
Mark
Old 12-03-2014, 10:29 PM   #7
trkfrk
trkfrk's Avatar
I removed the evap hose from the fitting in the intake manifold. It looks like the fitting is pressed into the manifold.
Mark
Old 12-03-2014, 10:54 PM   #8
ls1nova71
ls1nova71's Avatar
Yes, just put a vacuum cap on that and you're done.
Old 12-03-2014, 11:30 PM   #9
trkfrk
trkfrk's Avatar
Perfect. Thanks for reply.
My last question and then I can start ordering my fittings and filter to get the fuel system routed. There are 3 connections on my fuel pump. The connection on the far left is marked "R", I assume return. The far right connection is marked "F", I'm ussuming filter or supply/psi line. What is the middle connection for? Is it the evap connection? Can it be plugged or should it be vented? Or am I completely wrong?
Mark
Old 12-03-2014, 11:52 PM   #10
ls1nova71
ls1nova71's Avatar
You are correct on the feed and return lines. The tank DOES need to be vented somehow, so the center one can be run to a vent if your tank doesn't already have one. I'm assuming that is a Camaro fuel pump/sender assembly? If so, they are internally regulated and don't need the Vette regulator.
Edit: The more I look at it, that looks more like a truck pump/sender assembly. In which case you DO need the Vette filter/regulator.
