Old 12-12-2014, 10:57 AM   #26
lowlyfec10
Re: Will oil pan on truck motor be to low on lowered truck
ctsv and ls1 fbody pans are your best bet if super low or bagged. i have an fbody setup coming in monday so i can finally bolt my motor in. only thing is people want blood for used fbody pans. -_____- you can buy it new for $200 online (new gasket and bolts) and people want 200 for just a used pan by itself! gtfoh. got mine for 175 shipped and that has a new gasket and lokar dipstick
but im using cpp sheetmetal stands, poly mounts, and sliders......the truck pan hangs about 1-1.5" below the xmember
lowlyfec10 is offline   Reply With Quote
Old 12-12-2014, 11:48 AM   #27
Willie Makeit
Willie Makeit's Avatar
CTS-V with windage tray, pick up tube and dipstick - $179
http://www.ebay.com/itm/oil-pan-kit-...87cc54&vxp=mtr
CTS-V pan only - $125
http://www.ebay.com/itm/Cadillac-CTS...575c60&vxp=mtr
Willie Makeit is offline   Reply With Quote
Old 12-12-2014, 07:02 PM   #28
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Wasted Income View Post
Sounds like ECE needs to redesign their junk.
To be fair, they designed their mounts so that you could use the stock A/C compressor in the factory location.
Hart_Rod is offline   Reply With Quote
Old 01-08-2015, 06:28 PM   #29
Gooker928
Originally Posted by Hart_Rod View Post
Lots of clearance with the F-Body pan, but it WILL NOT work with the ECE LS conversion engine stand/mounts. The motor sits to far forward and the front of the pan will hit the cross member.
These mounts work great with the truck oil pan and BBC perches.
My oil pan sit level with my crossmember.
Gooker928 is offline   Reply With Quote
Old 01-09-2015, 01:56 AM   #30
slotard
What's a good oil pan for a basic work truck? I'd rather not have it hang way down... but more oil capacity is better. It might end up 4WD eventually.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-03-2015, 02:30 AM   #31
vman1213
vman1213's Avatar
Went with the Cadillac pan($125 ebay) and ebay slider mounts, dropped 5.5 in the front plenty of clearance. My buddy also used Cadillac pan with ece mounts his sits even higher.
vman1213 is offline   Reply With Quote
Old 02-03-2015, 08:23 AM   #32
homemade87
cts pan should work fine
homemade87 is offline   Reply With Quote
Old 02-08-2015, 03:59 PM   #33
kitsbeach
kitsbeach's Avatar
I'd like to see a comparison of the CTSV pan vs the F-body pan...
Sounds to me like the LH8 hot rod pan still hangs down pretty low for a dropped truck.
And, if I understand correctly, the F-body pan hits the crossmember if your motor is too far forward.?
Does the CTSV pan correct that and how much oil does it hold.?
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 02-08-2015, 04:10 PM   #34
H20cooled
http://ls1tech.com/forums/conversion...-oil-pans.html
H20cooled is offline   Reply With Quote
Old 02-08-2015, 04:43 PM   #35
68c10airstream
68c10airstream's Avatar
Hi kitsbeach, i used the f body pan, used the organ donor 2001 mounts, and made my own perches. I can barely sneak my little pinky between the front of the pan and the crossmember. The f body pan is the thinnest up front and my pan sump is about 3/4 inch above the lowest part of the crossmember so it's protected. When i mocked up my swap years ago i wanted to try and use the stock fanclutch/ 68 fan shroud/ 2001 hd radiator and it all worked out. This way i can source stock parts if needing replacement. My little pinky can't fit between the tips of the fan blade and the inside of the fan shroud but they never rub.
68c10airstream is offline   Reply With Quote
Old 02-08-2015, 07:41 PM   #36
kitsbeach
kitsbeach's Avatar
Originally Posted by H20cooled View Post
This is great..!! Thank you..!!
I'm with you on using stock style parts.! Especially helpful on a road trip.! Or if you don't want your truck off the road.!
Kitsbeach (Ken)
