07-07-2014, 10:16 PM | #1 |
Will oil pan on truck motor be to low on lowered truck
Wondering if the truck pan on a 5.3 will sit to low, my truck is lowered 2.5 in front. If it is to low what pan is suggested
07-08-2014, 12:41 AM | #2 |
meowMEOWmeowMEOW
Re: Will oil pan on truck motor be to low on lowered truck
The exact height will depend somewhat on what mounts you use, but usually the truck pans hang lower than most folks like on swaps. The "hot rod"/LH8 pan is a popular option, as is the camaro pan, or the aftermarket units if you have the $$ or have a unique clearance issue.
07-08-2014, 01:19 AM | #3 |
i used the stock truck pan with sb pedestals and ebay plates
pan hangs about 2.5" below the cross member |
07-08-2014, 09:55 AM | #4 |
I really like the Cadillac CTsV pans.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-08-2014, 11:39 AM | #5 |
Vintage Evil
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
07-08-2014, 11:57 AM | #6 |
I used the LH8 pan. It is the same one that is in the hot rod pan kit you can buy. Fits good, hangs about level with the crossmember.
07-08-2014, 02:38 PM | #7 |
I swapped and used a camaro pan. It works and fit great. I think the truck pan is always questionable on the height. It made me nervous using it.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-08-2014, 04:26 PM | #8 |
My truck is lowered about 4-4.5 inches in front with the stock truck pan. Im running it for now until I get a new pan. I just have to be careful when Im driving.
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
07-08-2014, 06:25 PM | #9 |
Fabricate till you "puke"
I used the LH8/ "hotrod pan"....you do lose about a quart + a 1/4 capacity , vs the truck pan. However, on a cruiser/driver, I don't see an issue. The pan kit is complete (Summit or Jegs), & includes all hardware, for about $150! No kidding, pan gasket, bolts, pump pickup, & windage tray & nuts! Its like a sore.... well,you get it, you just cant beat it For racing , or higher rpm apps, I do have to agree that the caddy pan looks like a better deal Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-14-2014, 08:51 PM | #10 |
Old member
Im running the stock pan as well but the truck is only 3" drop up front. The road would have to be deep out in the very center of it to get the pan are either your off the side of the road.
This it it sitting at running height.
07-15-2014, 09:13 AM | #11 |
Boosted Member
I ran a stock truck pan on my bagged c-10.
Pan hangs too low. Crown in the road got me....twice...
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
07-15-2014, 09:35 PM | #12 | |
Old member
Bagged truck I wouldn't run the truck pan on. Static drop off 3" it's fine I think. I haven't hit anything yet and that is 3300 miles on the 2014 Power Tour also.
07-16-2014, 08:37 AM | #13 |
Boosted Member
Yea, I was cruising pretty low
07-16-2014, 04:00 PM | #14 |
Old member
That what I figured. I can't think of any roads around here that you would even think about cruisin' layed out! The roads are not very good for that in our area!
I have had to rebuild the whole front end on mine since the Power Tour.
07-16-2014, 04:41 PM | #15 |
1965 Chevy C10, 2005 4.8L/4l60
I have a stock truck pan with ECE perches. I am lowered 4" with spindles and springs, I have not touched anything yet. If you have it out, go ahead and change the pan while you have it out.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-16-2014, 04:55 PM | #16 |
Stock truck pan for me with ECE 4/6 drop, and no problems yet.
07-16-2014, 07:13 PM | #17 |
Old member
Glad to see I'm not the only one running the factory pan.
07-18-2014, 07:56 AM | #18 |
I didn't like the fact that the truck pan still hung lower than the crossmember. I went with an Fbody pan. Plenty of clearance everywhere.
07-18-2014, 08:06 AM | #19 |
Lots of clearance with the F-Body pan, but it WILL NOT work with the ECE LS conversion engine stand/mounts. The motor sits to far forward and the front of the pan will hit the cross member.
07-18-2014, 09:05 AM | #20 |
Boosted Member
Sounds like ECE needs to redesign their junk.
07-22-2014, 08:33 AM | #21 | |
I used POL tubular stands with TransDapt adapter plates, and it's also in the 6-cyl location so it sits farther back. It's been a while since I measured, but I think there was still enough clearance if mounted in the V8 position. If one were to use the Dirty Dingo adjustable adapters with the POL or stock towers, the F-body pans will work. I'm not familiar with the layout of the ECE stands and mounts.
07-28-2014, 10:21 AM | #22 |
Lopped the bottom off the truck and welded a plate on and shortened the pickup. Or more accurately, Vic1947 did a fantastic job of it.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-10-2014, 09:08 PM | #23 |
Has any1 used the cadillac pan with ebay mounts? I'm lowered 5.5 in the front? Worried about pan hitting Crossmember didn't wanna buy ece mounts since I had these already
12-11-2014, 08:46 AM | #24 |
Hello to all. if you don't mind, I'll add my two cents. I have an air suspension, that previously used the truck oil pan. I attempted to modify the truck pan but was unsuccessful. In both cases of my oil pan modifications, I either lost oil pressure, or it leaked oil. I ended up buying the Holley 302-1. its a great oil pan. I wished I would have started with that oil pan in the first place. I had to add spacers to the engine mounts to raise the engine 1/4 inch, because the bottom of the oil pan touched the steering center link. one thing I will add is the dip stick tube (Holley suggest) is the same length as the truck dip stick tube. Also, the dip stick (Holley suggest) is approximately 1 inch shorter that the truck dip stick. good luck. Clark
12-11-2014, 08:51 PM | #25 |
CTS-V pan fan here too. Stock towers with Dirty Dingo sliders on a bagged truck. Pan is within a 1/4" of being flush with the cross member.
