Old 12-26-2014, 04:01 AM   #1
gmcdeadhead
gmcdeadhead's Avatar
fan shrouds
what other year truck fan shrouds, or car , would fit our 1966 v8 truck with little or no modifications?
gmcdeadhead is offline   Reply With Quote
Old 12-26-2014, 05:35 AM   #2
pimpston65
pimpston65's Avatar
Re: fan shrouds
im sure as long as its wide enoughto attach to the side wings any one will fit, i have one from 67-72 era im not using, you can have it!!!
pimpston65 is offline   Reply With Quote
Old 12-26-2014, 05:22 PM   #3
gmcdeadhead
Re: fan shrouds
pm sent pimpston65
Old 12-26-2014, 06:39 PM   #4
southern parts
southern parts's Avatar
Re: fan shrouds
I have a 64 impala fan shroud on my 64 burb. had to trim a little off the flanges on each side.
southern parts is offline   Reply With Quote
Old 12-26-2014, 07:21 PM   #5
duallyjams
duallyjams's Avatar
Re: fan shrouds
got a pic to share
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-27-2014, 11:56 AM   #6
southern parts
Re: fan shrouds
I forgot , I also trimmed some off of the tunnel part too
Old 12-27-2014, 10:35 PM   #7
DPowers
One foot in front of the other
DPowers's Avatar
Re: fan shrouds
I have two V8 ones if you are interested. Both would need minor repair.
DPowers is offline   Reply With Quote
Old 12-28-2014, 01:30 AM   #8
algiese
Re: fan shrouds
Also looking for a V8 shroud....
90810 Long Beach Ca
algiese is offline   Reply With Quote
Old 12-28-2014, 01:59 AM   #9
Kenfuzed
Kenfuzed's Avatar
Re: fan shrouds
I had been looking for one but finally grew impatient and bought an aluminum shroud kit from Summit. I had to trim the hoop back since my engine sits forward and the fan needed to be half in half out for proper flow. But if the engine sits in the rear (stock) position the ring doesn't need modifying.
Here are the fan shrouds. You'll want to select one that is closest in dimensions to reach around whatever radiator you are using.
http://www.summitracing.com/search/p...=Fan%20Shrouds
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-28-2014, 04:46 AM   #10
Grizz1963
Grizz1963's Avatar
Re: fan shrouds
One of the things I need to figure out on my rebuild.
My shroud is zip tie special with much thick black brush paint.
Need to find a decent donor in the UK.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-28-2014, 03:36 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: fan shrouds
Ken, your summit shroud kit looks great!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-28-2014, 05:49 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: fan shrouds
I agree!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-29-2014, 02:03 AM   #13
Kenfuzed
Kenfuzed's Avatar
Re: fan shrouds
Thanks, I actually consider myself fabricated-challenged so if I could do this almost anyone can. It would be easier for anyone not needing to trim the width of the ring. The stock width would have placed the fan too deep for me. The band is a long strip that is approx 3" wide so I took a jig saw and ripped down the length to remove around 1.25" of the width. I recommend this shroud kit for anyone wanting an efficient solution and not requiring an original shroud.
Enjoying the ride!
Old 12-29-2014, 03:41 AM   #14
gmcdeadhead
Re: fan shrouds
how well does the shroud from summit racing move air?
Old 12-30-2014, 02:07 AM   #15
Blainethemono
Blainethemono's Avatar
Re: fan shrouds
Ken, that's your std Chebie small block I assume, & do you remember the part number from summit? The 19" one perhaps.
Thanx!
Blainethemono is offline   Reply With Quote
Old 12-30-2014, 02:38 AM   #16
Kenfuzed
Kenfuzed's Avatar
Re: fan shrouds
I can feel air being pulled from the front even in the corners. At high idle it will hold a dollar bill against the front of the radiator, but then again my truck can find a way to suck money just about anywhere.
Thanx!
Found my order info, here is the link.
http://www.summitracing.com/parts/SUM-380482-SH
The shroud's box portion is 19x26 which fit pretty good around my Champion aluminum radiator.
Enjoying the ride!
Old 12-30-2014, 11:21 AM   #17
pimpston65
pimpston65's Avatar
Re: fan shrouds
here are pics of the 67-72 style i have...
Old 12-30-2014, 11:22 AM   #18
pimpston65
pimpston65's Avatar
Re: fan shrouds
another pic
