#26 |
Re: big blocks...
Right on bro!! With a 6 speed to back it up, love it!!!
#27 | |
Re: big blocks...
http://ls1tech.com/forums/forced-ind...kes-920rw.html
#2 I purposely fudged WAY LOW on my previous LS turbo power statement so as not to sound foolish to the unitiated. How does 920 rear wheel horsepower on a $150 4.8 grab you? Sounds unbelievable doesn't it? It's not. GM really outdid themselves with the LS platform, and we should all be thankful. I've been extremely fortunate to have participated in Hot Rods Drag Week. Let me just say to dismiss a turbo LS as not being everything and more (except the sound!) of a big block is a bit naive. The general has offered the gift of ludicrous speed, in both big block and LS form. We should all be glad were not Ford guys. .. |
#28 |
All about them K’s
![]() Join Date: Jun 2014
Re: big blocks...
Haha! I thought ford stood for first on race day??? At least that's what they'll tell you!... We all know the truth here tho! Amen we've been blessed to be able to go fast pretty easily with multiple engine platforms!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#29 | |
Re: big blocks...
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
#30 |
Re: big blocks...
I agree that LS motors can make colossal power... but at what cost? If I put the same amount of money into a big block, as they do to make an LS produce 1000 HP... what would I have? There is no replacement for displacement I understand that. It comes back to the rice burner 4 bangers making 300 HP... I hallways tell those guys "great, you spent $2000 to make as much HP as a stock v8. If I spent $2000 on my v8 I could make 600-700 HP."
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
#31 |
Re: big blocks...
Why has this turned into a debate about ls vs big blocks? I say pick up your roller big block and have a blast!
#32 |
Re: big blocks...
And you guys think 700 ft. lbs. of torque is impressive...
#33 |
I built it
Re: big blocks...
the only way someone could force me to run a ls in my truck is carb'd and 427ci+. next engine under my hood is gonna be a 489... or maybe a 540...
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
#34 |
Re: big blocks...
are you referring to your 4bt?
#35 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: big blocks...
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#36 |
Re: big blocks...
I wish it was a 409, but its a 348 which I dropped off this morning to be bored .030. Yes, it will have 3x2s on top. Love the look. Just a mild cam for a daily driver..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#37 |
Re: big blocks...
Nothing wrong with a 348 and thought it may be one as well. In 1971 I had a 58 Chevy Impala 2 door with a 348 ( 4bbl 250hp) and 2 speed powerglide trans. I drove the crap out of it ( as most 22 year olds did back then) and blew up the powerglide and a lot of the gears were split in half ..
#38 |
Re: big blocks...
small blocks are for cars BIG BLOCKS ARE FOR TRUCKS, as simple as that !
#39 |
![]() ![]() Join Date: Jan 2011
Re: big blocks...
Ok, I'll play - the turbo LS motor spec is right on and no disrespect to the LS guys out there. You can make a ton of power with those engines. I get it..
But - put the same turbo on the big block and what happens? With a nice set of heads and the right ' old school tuning ' from the old timers I'm good with my BBC. Honestly I don't know enough about the LS motors to even talk about them but how can they be as fuel efficient as people claim when the Z06 factory window sticker doesn't claim the same mpg rating overall? Just sayin..
#40 |
Re: big blocks...
X2 on 1996. Any 454 marked as a Vortec or Vortec 7400 should have a roller cam. (You'd also get the better-flowing Vortec heads with that package.) Not sure about previous versions or some of the late 80's/early 90's hi-perf car variants, but I believe in trucks the flat-tappet to roller change came with the Vortec induction system in '96.
My BIL's family has a '98 K2500 Suburban w/454, and with the only upgrade being Flowmaster exhaust it'll flat haul their 32' cargo trailer. Gets 14 MPG or so empty, with 4.10 gears. 250,000 miles and counting. Two pages of discussion and only one other direct answer to the man's question... tisk tisk.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
#41 |
Re: big blocks...
My 454 .40 over Gen. 4 Big Block
-GM Truck Heads -Hydraulic Roller -Comp Thumper Cam -Steel Crank -Aluminum Forged Pistons Engine Dyno: 375 HP 475 Torque
343 NEVER FORGET 9-11 FIGHT ON!!! GO USC!!! PROUD OWNER OF A 1970 ![]() |
#42 |
Re: big blocks...
On Dyno
#43 |
![]() Join Date: Jul 2015
Re: big blocks...
#44 |
Re: big blocks...
i would recommend going away from a v-belt if you do the swap, and go with a ribbed belt, they are so much easier to install, and just look better in my opinion
#45 |
Re: big blocks...
serp belt setup
#46 |
Re: big blocks...
7.5 mpg which is a little worst than my 402 that was 8. I have a TH-400 trans. I currently have 3.73s but want to drop down to 3.42s, I'm spinning 3000 at 70 on the fwy and would like to drop down. But in all it sounds mean and cruises. I put polyurethane engine mounts but I put a new stock style trans mount. Doing polyurethane all the way was TOO MUCH vibration!!!
#47 |
![]() Join Date: Jan 2002
Re: big blocks...
Big blocks are so much fun! Can achieve a lot of torque out of them!
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#48 |
Re: big blocks...
#49 |
Re: big blocks...
How do you figure driveability suffers? Is it because the wheels never hook?
#50 | |
Re: big blocks...
A big block with a factory-calibrated Q-jet drives like an LS3, it just gets a lot worse mileage. It's when kids monkey with them and rip off all the pieces that don't make power that you wind up driving it with two feet so it doesn't stall, and that gives them a bad name. Properly set up, they should run perfectly.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
