big blocks...
Hey guys, I was reading a thread about big blocks and someone mentioned a full roller engine... what year did gm begin installing these in trucks? I have seen a few 454 complete vehicles on cl now for under $1k, trying to decide what direction I want to take my truck... also, how much weight will I gain with the 454 and what is the hardest part of the install?
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
![]() Join Date: Aug 2009
Re: big blocks...
The hardest part is keeping your foot off the gas pedal, lol
All about them K’s
![]() Join Date: Jun 2014
Re: big blocks...
To my knowledge the late model 454 is roller cam only no roller rockers...so not a full roller motor. my 98 factory big block k2500 with the original motor doesn't have roller rockers. I don't even think the 8.1 had them but I could be wrong. They can be added but you need tall valve covers. factory Roller cam 454s are hit and miss in the early tbi motors but I'd be willing to bet that by the the early 90s all the way up thru the vortec motors all have roller cams.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Re: big blocks...
That's is the truth!
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
Re: big blocks...
Actually an aluminum headed and manifold on a big block will be almost the same weight as an iron head stock small block. The Dart block with billet caps is about 20-25 lbs heavier than a stock block. And yes the later model engines where the roller design.
Re: big blocks...
Why in this day would you swap to a Big Block? For about the same money you can have an LS that is lighter and more fuel efficient while having the same power. I can understand keeping a big block if you already have one, but swapping from small block to big is hard to figure. You need mounts, manifolds, accessories and other parts that are BB specific and expensive. I am not against BB really, I just think there is a reason they don't make them anymore.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#7 | |
Re: big blocks...
All about them K’s
Re: big blocks...
Ask Stacy David. Copperhead is a wicked truck!
Re: big blocks...
Big block is the only way to go.
1972 Chevy shortbox, done up 396bbc 1968 Plymouth Roadrunner, 1000hp twin 72mm turbos 2017 F350 Lariat, 6.7, stock except leveling kit and larger tires 2014 nissan pathfinder sl (the kid hauler) |
#10 | |
Re: big blocks...
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#11 | |
Re: big blocks...
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
Re: big blocks...
for me it was sourceing all the right parts too make everything work right.
my choice of headers was the biggest deal too work around with the crossmember and clutch linkage. dont get me wrong sbc's are awesome and i'm growing more fond of the ls engines but theres nothing like popping the hood and haveing a huge rat looking back at you.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#13 |
Re: big blocks...
back to the OP's question I believe they started in 96 with the roller cams in the BBC
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#14 | |
Re: big blocks...
But now, everyone and their brother has a turbo LS making 500+ hp. At the rear tires. The horsepower on the streets these days is INSANE. |
#16 |
![]() Join Date: Nov 2013
Re: big blocks...
depends on what you want
small block good driver ls good driver good hp big block old school torque, hp and looks, but gas suffers as does driveability |
#17 |
Re: big blocks...
I'm with niped I just swapped in a big block into my 67 and wouldn't have it any other way. When I go through down and see people turn just from the sound of the truck it's worth it. Plus I've never had anyone frown after riding in that truck.
I'll keep my rat's |
#18 | |
All about them K’s
Re: big blocks...
![]() Quote:
#19 | |
![]() Join Date: Jul 2009
Re: big blocks...
#20 |
Re: big blocks...
Mine came from the factory with 396 cu in big block & I wouldn't have it any other way! There's no replacement for displacement!
"Now all I need is a shop to go with my shop vac!" ![]() |
#21 |
Re: big blocks...
Big blocks just create such low end torque and the curve is dam near flat through the entire range. My 462 BB makes tree stump pulling torque in my 70 C10. Dyno'ed at 475 hp/500 tq all below 5000 RPM's. This engine was built to be mild by BB standards for drivability and be street friendly.
Now I'm saying one is better than the other as my Camaro has an LS making 630hp/599tq but is wound up tight at 7000 RPM's. Yes it is a go fast car that runs 10.9 1/4 mile times with ac and all. I like the camaro but love driving that deep sounding BB truck.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club Last edited by CST10; 01-01-2015 at 12:57 AM. Reason: Typo |
#22 |
Re: big blocks...
Originally I wanted to build a daily driver, but after examining the fact that I couldn't drive it daily because I have to pick up 2 kids in car seats sooo...... I have decided I want a fun toy. And it seems to be easier to get a full bb vehicle than just an ls engine. Ls engines have become so popular that they are expensive. Whereas I can find a roller bb tahoe for about $1k.
#23 |
Re: big blocks...
Big blocks are nice, small blocks are nice, Dressed in chrome, dressed in orange, stock, sooped up, open the hood and everyones got one. you know what to expect. I'm going the other way. (my wife wants to know why I always have to be different).. Just got the 3x2 bbl setup comming. can't wait!
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 01-01-2015 at 02:45 PM. |
#24 | |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Re: big blocks...
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#25 |
Re: big blocks...
At 500 you are STILL 150 HP away from that big block. And It does it reliably on pump gas. The main difference is the torque. Your turbo smallblock will peak at about 450 ft-lbs. That big block peaks at 650 ft-lbs and it is torque not horsepower that gets you off the line.
