01-10-2015, 06:50 PM | #26 |
Re: My suburban's Twisted Little Sister
I'm along for the ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
01-10-2015, 08:45 PM | #27 |
I'm really liking the frame your doing!!
nice work.. Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
01-11-2015, 02:01 PM | #28 | |
Enjoy the ride Rusty Thanks Reaper. Building the frame is kind of fun. Here's Fridays progress. We Tig welded most of the perimeter frame, until we ran out of argon. then we tacked some sub assemblies
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
01-11-2015, 02:53 PM | #29 |
Between saying and doing many a pair of shoes are worn out |
01-12-2015, 08:10 PM | #30 |
Got a new plasma cutter on the weekend. So today we started by cutting the 90* frame bends into two 45* bends. Then we made a temporary gig to tack the sub assemblies
01-14-2015, 10:35 PM | #31 |
We did a bunch of tig welding and grinding on the sub assemblies yesterday. Today we clamped the front corners in place then tack welded them
01-14-2015, 10:48 PM | #32 |
Killer work
01-15-2015, 10:53 PM | #33 |
Thanks rusty
Thanks reaper Frame work is fun Thanks for following hotrod Thanks Free Candy I am watching your cool panel build as well Today we started modifying the front crossmember. First we made a 1/4 X 2 plate with two nuts welded to one side. Welded it to the mounting point for the frame. Then we started cutting the 2X4 frame section
01-15-2015, 11:05 PM | #34 |
SAVING ONE TRUCK AT A TIME
Great build you have going on. Its probably to early to tell but how do you like the versa cut 60? I have been looking at it for awhile. It had very good reviews.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
01-15-2015, 11:09 PM | #35 |
Very COOL project! Nice work.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
01-16-2015, 11:43 AM | #36 | |
Thanks Joe
01-16-2015, 12:02 PM | #37 |
"SUB" assembly? short for suburban assembly hehe, dude this build is by far the most, i don't even know what to say other then AWESOME!!! fast and can corner with the best, heck you can autocross that beast!!!
01-19-2015, 09:56 PM | #38 | |
Todays work. First we made an angle bracket to bolt to the crossmember. Bolted everything together and tacked it to the 2X4 tubing. The next step was to start building the transition between the2X6 and 2X4 sections
01-20-2015, 11:06 AM | #39 |
looking really good...
01-21-2015, 09:14 PM | #40 |
Thanks reaper
Started working on the front frame rail for the drivers side. In the first picture notice the angle between the horizontal and vertical where the frame rail sits. In the second picture we cut a 3/8 strip out of the bottom of the frame rail and two cuts on the side. Then used clamps to bend side. The third picture is the side tacked
01-22-2015, 08:35 PM | #41 |
Today we finished making the drivers side front frame rail. Cut two crush sleeves and welded them in. Last two pictures are with the front frame rails tacked in place.
01-22-2015, 08:41 PM | #42 |
i see why you called it twisted, with all those "twists" and turns and the frame rails. like i said if you need a shop hand/whipping boy im your guy!!! what thickness on the frame rails are you using!!!
01-22-2015, 08:44 PM | #43 |
Picture one is some of the tig welding on front frame. The last two pictures show the rear inside corner tacked in and some plasma cutting on the rear corvette section
01-24-2015, 12:02 AM | #44 |
1961 crewcab
cool so far! frame is interesting, but I can't wait for the body mods!
maybe this is what I should do with my 1990 corvette!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
01-24-2015, 12:23 AM | #45 |
65sub, outstanding project and really love the frame work! Very creative...and a lotta skill there too. I am all in to tag along.
01-24-2015, 09:00 PM | #46 | |||
Friday's work was just welding and grinding on the front of the frame. Here's three pictures of the finished welding
01-25-2015, 09:00 AM | #47 |
Fantastic looking work on the frame. Looking forward to following your build.
01-25-2015, 11:03 AM | #48 |
Awesome work.
01-26-2015, 10:13 PM | #49 | |
First two pictures we put the front suspension back together Next, after some careful measuring we removed the rest of the corvette frame and left the rear suspension on the table. The last shot is the first two pieces of the rear frame section
01-27-2015, 05:42 PM | #50 |
Man o man this is one awsome build you got going on here! Gonna be following this! Just out of curiosity why you using a Corvette for suspension?
