01-20-2015, 11:06 AM | #1 |
Re: My suburban's Twisted Little Sister
looking really good...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
01-21-2015, 09:14 PM | #2 |
Thanks reaper
Started working on the front frame rail for the drivers side. In the first picture notice the angle between the horizontal and vertical where the frame rail sits. In the second picture we cut a 3/8 strip out of the bottom of the frame rail and two cuts on the side. Then used clamps to bend side. The third picture is the side tacked
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
01-22-2015, 08:35 PM | #3 |
Today we finished making the drivers side front frame rail. Cut two crush sleeves and welded them in. Last two pictures are with the front frame rails tacked in place.
01-22-2015, 08:41 PM | #4 |
i see why you called it twisted, with all those "twists" and turns and the frame rails. like i said if you need a shop hand/whipping boy im your guy!!! what thickness on the frame rails are you using!!!
01-22-2015, 08:44 PM | #5 |
Picture one is some of the tig welding on front frame. The last two pictures show the rear inside corner tacked in and some plasma cutting on the rear corvette section
