Old 01-13-2015, 10:18 PM   #1
gasmn1620
rebuilding my entire front end... advice
Ok, I'll be replacing upper and lower a-arms with new ball joints, drop spindles ( probably mcgaughys unless there is a better option), new tie rod ends, new shocks, drop springs, all new brakes, and all of the wheel bearings. What brands would you guys recommend for the bearings, drop shocks, springs, and spindles. The a-arms will be junkyard rebuilds. I have energy suspension bushings for the whole truck. Someone said to swap the pitman arm out while I'm in there. Any other suggestions. Gotta get this done because my front end is roaring from the bad bearing and old rusty brakes.
gasmn1620 is offline   Reply With Quote
Old 01-13-2015, 10:30 PM   #2
83swb
Re: rebuilding my entire front end... advice
If you do control arm bushings go with polyurethane bushings that use the factory sleeves, or you will regret it after a weekend of unnecessary work (ask me how I know). Sounds like that's what you've already purchased, the old bushings are really "fun" to get out.
Don't think you can beat MOOG for steering components and balljoints.
For lowering components don't run anything off brand, a quick google image search will prove why you shouldn't go that route. I used western chassis parts for my build and they seem to build a quality, reasonably priced product.
83swb is offline   Reply With Quote
Old 01-13-2015, 10:49 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
I use Moog for all tie-rods, pitman, idler, and bushings.
The A arm bushings will kick your a*s if you remove the factory sleeves. Not fun at all. Best way I found was to get a 1/4" drill bit and drill through the rubber at as many intervals as you can. That helps weaken and break up the rubber to get it out.
Old 01-13-2015, 11:06 PM   #4
83swb
x2^ Make sure you have some ventilation in the area your drilling, those things smoke and smell nasty when drilling or torching them out , not the enjoyable smell of burning rubber you may be thinking of.
Old 01-14-2015, 02:14 AM   #5
rich weyand
rich weyand's Avatar
Second Moog parts. Put 'em in once and forget about 'em.
While you're doing all that, you might want to put the frame reinforcement in at the steering box.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 01-14-2015, 04:05 AM   #6
Jaysonb
Jaysonb's Avatar
You can make quick work of the control arm bushings by cutting through the rubber with a hole saw, then knock out the metal with an air hammer.
Jaysonb is offline   Reply With Quote
Old 01-14-2015, 08:16 AM   #7
Kaysen
^^^Never thought of that with the hole saw, but good idea!
Kaysen is offline   Reply With Quote
Old 01-14-2015, 10:09 AM   #8
77c10
77c10's Avatar
Might as well replace the idler arm while you are doing it....
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 01-14-2015, 10:20 AM   #9
gasmn1620
Do we have any supporting vendors that are moog dealers? Advance auto has a sale going. I can get all the balls joints, inner and outter tie rods, the problem solver upper control arm rods shipped for around 360.
Old 01-14-2015, 10:34 AM   #10
77c10
77c10's Avatar
I bought all my front end parts from Rock Auto. I don't remember the brand though.
Old 01-14-2015, 11:51 AM   #11
gasmn1620
thanks!! Rock Auto is about $140 cheaper!
Old 01-14-2015, 11:56 AM   #12
86c20
86c20's Avatar
napa blue boots. they are the high end of napa. have had good luck with them when i could not get the moog parts as fast as i needed. still working good but for 10 bucks more i want moog. if for nothing else i better name lol
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-14-2015, 12:27 PM   #13
77c10
77c10's Avatar
You have to watch them at times though, they will ship from two or three different places and the shipping will rack up on you. I still saved money buying from them even after shipping though.
Old 01-14-2015, 12:28 PM   #14
gasmn1620
just got all the stuff from rock auto. Went ahead and got the idler arm and pitman arm too for less than the other stuff was at advance. Thanks guys.
Old 01-14-2015, 12:29 PM   #15
gasmn1620
now i just have to figure out which drop spindles to get. Read a lot of bad about djm and some good about mcgaughys. any input?
Old 01-14-2015, 12:42 PM   #16
Joeys82c10
Advance use code trt30 or trt41. Break it up into smaller order so you get the max discounts.
Joeys82c10 is offline   Reply With Quote
Old 01-16-2015, 02:22 PM   #17
gasmn1620
what brand wheel bearings do you guys use?
Old 01-16-2015, 02:38 PM   #18
Joeys82c10
American.
Old 01-16-2015, 07:54 PM   #19
74CustomK20
74CustomK20's Avatar
Originally Posted by Joeys82c10 View Post
American.
HELL YEA! Timeken always has good bearings and done me good in my transfer case and SM465
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 01-16-2015, 07:55 PM   #20
gasmn1620
I narrowed it down to Timken or oem replacements. Definitely not getting ebay or auto zone bearings.
