Old 02-23-2015, 10:19 PM   #1
suburban99
suburban99's Avatar
62 with 78 front end and 2000 5.3 power steering question
Ok, I have a 62 C10, converted to 78 front end for disc's and a 78 power steering box..(i think) ready for power steering hose. What have you guys used? Return side no biggie, talking pressure side. Thanks
suburban99 is offline   Reply With Quote
Old 02-24-2015, 06:13 AM   #2
dec010974
dec010974's Avatar
Re: 62 with 78 front end and 2000 5.3 power steering question
I used braided line. The fittings were adapted for the pressure, and none pressure side. An option would be to go and have the line made from a hydraulic shop. You would def. need the ends for a proper match. you can buy new ends from the auto parts store or grab some from the JY. BTW, That engine bay is sexy.
dec010974 is offline   Reply With Quote
Old 02-24-2015, 12:14 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You can just swap the end-fitting at the box if you have the stock line to work with. OR you can cut and flare the correct ends on the "old" or the "new" hose, since you will have different fittings on each side.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-24-2015, 12:22 PM   #4
ls1nova71
ls1nova71's Avatar
Or you can find out exactly what year of steering box you have. If it were to be a newer one than a 78, say an 81ish or newer, you can get a hose for a newer truck and you would have o ring fittings on both ends.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-24-2015, 10:03 PM   #5
earl84
Can't help with the proper hose, but I would do a search on Rockauto.com for different years until you found one that is close to the same length for what you need. The PS pump pressure side will be a 16 x 1.5 O ring fitting and can almost guarantee that your '78 PS gearbox pressure inlet side is a 11/16-18 thread with a 7/16 inverted flare. You can either cut off the PS gearbox end and flare it, or get an adapter fitting.
earl84 is offline   Reply With Quote
Old 02-24-2015, 10:26 PM   #6
truckdude239
truckdude239's Avatar
I used the stock hose and swaped the 1 inch fitting out of the back of my stock pump and installed it in the back of the ls pump and the st9ck line worked
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 02-24-2015, 11:19 PM   #7
tbrown5079
My local mechanic also makes hoses so I just took the ends I needed, had him make new ones to match. Then he sent me home with 2 rolls of hose. I measured and cut them , took them back and he crimped the ends and charged me for ends. crimping. and the hose I used. I don't know if it was the cheapest route but I know I have what I needed.
tbrown's 56 Cameo Build
tbrown5079 is offline   Reply With Quote
