03-24-2015, 10:44 AM | #251 |
Re: My 1952 truck.
looking stellar, I like the latch. Was debating on doing that too. Maybe on my next build.
I'm assuming you have repro parts there you have to fix??? not the only guy I'v seen having to do that.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
03-24-2015, 12:03 PM | #252 |
Re: My 1952 truck.
Yes they are Dynacorn fenders. Not too happy with them or the other panels.
Wade |
03-24-2015, 01:17 PM | #253 |
Re: My 1952 truck.
And the beat goes on.....
Wade |
03-24-2015, 01:19 PM | #254 |
Re: My 1952 truck.
Wow! Ok, I have the hood fitting. Now to put the grille in and see how much work is there.
Wade |
03-24-2015, 01:24 PM | #255 |
Re: My 1952 truck.
Fender tips now I guess.
Wade |
03-24-2015, 04:47 PM | #256 |
Re: My 1952 truck.
That is going to be a killer motor!!!! Lookin good.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-27-2015, 08:23 PM | #257 |
Re: My 1952 truck.
Finishing up my rad cover today. The fit to the grille is awful. Had to add a fair amount of metal.
Wade |
03-27-2015, 08:25 PM | #258 |
Re: My 1952 truck.
Got the pieces made and tacked in.
Wade |
03-27-2015, 08:26 PM | #259 |
Re: My 1952 truck.
I'm not in love with grinding but it is looking ok.
Wade |
03-27-2015, 08:28 PM | #260 |
Re: My 1952 truck.
I'm happy with it. Needs a little filler but I wanted this fitting nice.
Wade |
03-27-2015, 11:23 PM | #261 |
Re: My 1952 truck.
looking really good, good god Id be so mad to have to do all that work to make new panels work ($$). I guess there is just never an easy way to get one of these trucks done. new or old metal, lotta work.
03-28-2015, 08:55 AM | #262 |
Re: My 1952 truck.
Nice work. Wonder if the gaps / poor fit is due to variations in the original builds or are the new parts that far off?
03-28-2015, 01:43 PM | #263 |
Re: My 1952 truck.
I'm not sure AD, it does seem weird everything is off on the front end. My truck is a model 1433 which is a Canadian 1 ton. I was told the hoods a bit different?
Wade |
03-28-2015, 10:18 PM | #264 |
Re: My 1952 truck.
1/2-1 ton chevy are all the same front sheetmetal. 1.5 ton and up changed, everything is a bit bigger.
03-29-2015, 10:55 PM | #265 |
Re: My 1952 truck.
Cool.
Wade |
03-30-2015, 07:49 PM | #266 |
Re: My 1952 truck.
Started on lower dash today. Got the idea to use a spare set of defroster Vents.
Wade |
03-30-2015, 07:51 PM | #267 |
Re: My 1952 truck.
My center duct will go into my console.
Wade |
03-30-2015, 07:53 PM | #268 |
Re: My 1952 truck.
I will be gluing in a piece of foam in these vents after paint. Ducts worked great.
Wade |
03-30-2015, 09:49 PM | #269 |
Re: My 1952 truck.
I envy you with that dash!!!! nice filler piece, looks like it belongs there.
03-30-2015, 10:15 PM | #270 |
Re: My 1952 truck.
Thanks. I am going to make a polished moulding that will bolt on just over the vents and carry over onto the door panels and console.
Wade |
03-31-2015, 05:19 PM | #271 |
Re: My 1952 truck.
Great idea! Came out really nice.
04-01-2015, 03:14 PM | #272 | |
Re: My 1952 truck.
The script style CHEVROLET on your tailgate, is that raised aluminum or what? Looks real nice like that.
My Build: 57 Chevy Pro-Street |
04-02-2015, 08:38 AM | #273 |
Re: My 1952 truck.
pct, I took an old corvette valve cover down to the laser cutter. Had them cut me one 3' wide out of 3/16 stainless. Then I traced the outline onto a flat piece of metal. Then drilled holes within the outline, put the script in place and welded from the back. Then I cut out the original script and welded new script in. After paint I will sand the color off the script before it is cleared.
Wade |
04-02-2015, 06:12 PM | #274 |
Re: My 1952 truck.
Capped of the bed rails today and worked on tailgate gaps.
Wade |
04-02-2015, 06:14 PM | #275 |
Re: My 1952 truck.
Worked a bit more on lower dash. Cut and fit in my console.
Wade |
