Old 04-22-2015, 10:57 PM   #1
eke82
where to go for leaf springs and eaton brake parts
i have a 72 3/4 4x4 i need to replace rear springs and the rear brake lines and going to go thru the eaton rear axle while i am at it. i am keeping it stk height and don't want it to ride like a lumber wagon i will be putting a set of air bags in for trailer pulling purposes. where has every one gone for parts for these trucks and where to stay away from?
thanks eric everingham
eke82 is offline   Reply With Quote
Old 04-23-2015, 01:14 AM   #2
swamp rat
swamp rat's Avatar
Re: where to go for leaf springs and eaton brake parts
I can't tell you directly but its been covered a number of times, probably Napa would be a good place to start for break stuff..
My grandma, Grandpa and dad were from Stromsburg and Norfolk, i have been there as a kid and had a great time in a park there amongst other things.
As far as springs BDS and SD Truck Springs are a couple right off hand.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-23-2015, 10:55 PM   #3
odis.dunkle
I am a '69 C25 and just got my order from LMC (near you in KS) for leaf springs (plus lots of brake parts, but not brake lines).
I am a little concerned because with the "5 leaf spring" setup that they sent they counted the overload as a leaf so I am one leaf short of the 5 + 1 setup that is original to the truck. (I will do some HW, but I expect I will just use the ones they sent.) Other than that, the parts look to be fine (good match) and were definitely cheaper than the Oregon place I had found that would build them from scratch. LMC had the U-bolts and shackles, too.
I can let you know about the fit after they are installed if you want.
'69 3/4t 2wd
350 V-8, LWB
Auto trans, power steering
odis.dunkle is offline   Reply With Quote
Old 05-02-2015, 04:18 AM   #4
odis.dunkle
FWIW, my LMC experience was a bust. The leaf springs I rec'd weren't the right set up of center pin to ends. I really wish the LMC catalog had specs or better descriptions....
I am taking swamp rat's lead and have parts from SD Truck Springs on the way. They do list measurement specs, so I expect no problems. And they were 20% less expensive than LMC. Wish I had found them sooner.
'69 3/4t 2wd
350 V-8, LWB
