Old 04-29-2015, 10:40 AM   #101
samples45
samples45's Avatar
Re: 1955 (2nd gen) first timer..
Originally Posted by murd969 View Post
Looks good. How big is the notch that you did for the rear?
Thanks man! I'll do some measuring for you when I get home I forgot lol
Im also gonna pm you back about the coilovers today
samples45 is offline   Reply With Quote
Old 05-02-2015, 01:31 AM   #102
hp1957
hp1957's Avatar
Originally Posted by samples45 View Post
Ive always heard that your bottom Arms need to be level when setting up your ride height..not sure if they have to be dead straight even, but heres mine..If for some reason that wont work please let me know
Attachment 1396893
Attachment 1396894
I also had to do a c notch in the rear to be able to keep the half shafts level..I think they are suppose to be level.. or close lol I dont know much about this vette stuff im just goin off the pictures i have seen here so hopefully some one can chime in if something doesnt look right!
Attachment 1396901
Attachment 1396902
Attachment 1396903
Cameron, your rear suspension looking real good ! Rear half shafts need to be parallel to the ground for the best ride quality, say you have six inches of total rear travel 3in up & 3in down with the half shaft u-joints. Close up pic Bro Mario 56 GMC rear half shaft parallel to the ground at ride height.
Harvey
1957 Chevy Stepside
1958 GMC Fleetside C4 build thread: http://67-72chevytrucks.com/vboard/s...=535686&page=6
hp1957 is offline   Reply With Quote
Old 05-02-2015, 10:42 PM   #103
samples45
samples45's Avatar
Harvey
1957 Chevy Stepside
Thanks harvey!!
Old 05-02-2015, 10:46 PM   #104
samples45
samples45's Avatar
Got some brackets made for the corvette rear end.. almost had it done ran out of wire on the mig
cleaned up the rear end a little bit. that aluminum sure does turn out nice!
Old 05-02-2015, 11:36 PM   #105
oldman3
oldman3's Avatar
Seem like when you need the welder the most, it runs out of wire or gas on the weekend...Jim
oldman3 is offline   Reply With Quote
Old 05-02-2015, 11:48 PM   #106
Advanced Design
Advanced Design's Avatar
Looks good Samples. Seems wire or gas does like to run out on the week end.
Advanced Design is offline   Reply With Quote
Old 05-03-2015, 08:31 AM   #107
samples45
samples45's Avatar
Thanks AD! And it sure does.. I knew it was goin to because it started poping a little bit, the spool is so big the wire gets a little rusty towards the end lol
Old 05-03-2015, 01:14 PM   #108
Kim57
Kim57's Avatar
Looking real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-03-2015, 06:00 PM   #109
Advanced Design
Samples, did you figure out if bag brackets will work?
Old 05-03-2015, 11:20 PM   #110
samples45
samples45's Avatar
Originally Posted by Kim57 View Post
Looking real nice.
Kim
Thanks Kim!
Old 05-03-2015, 11:22 PM   #111
samples45
samples45's Avatar
AD, I'm not gonna use air ride.. I looked into some air over shock kits and they were a little much for me! I'm just gonna use coilovers front and rear!
Old 05-25-2015, 08:48 PM   #112
samples45
samples45's Avatar
Well im trying to set up the driveline.. im gonna have to notch that crossmember.. can someone tell me what angle my rearend is suppose to be? my trans? what angle should the driveline be? i have no ideal where to go from here.. thats just a mock up driveline by the way
Old 05-25-2015, 09:31 PM   #113
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Carb flange should be set level, this usually results in the trans being about 3* down.
ChuckDriver is offline   Reply With Quote
Old 05-25-2015, 09:38 PM   #114
samples45
samples45's Avatar
If I set carb flange level I'm pretty sure I'd have to run a tunnel through the whole cab..
Old 05-26-2015, 11:00 AM   #115
BIGglaSS
BIGglaSS's Avatar
Can you get the engine lower? Get your engine set where it needs to be. Then match the pinion angle the same as the crankshaft.
BIGglaSS is offline   Reply With Quote
Old 05-26-2015, 12:47 PM   #116
Dan in Pasadena
Dan in Pasadena's Avatar
Hmmm, such a simple and obvious rule of thumb that I'd never thought of before. I knew the driveshaft angle was usually 3 degrees downward to the rear but ever knew where that came from. Live and learn!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-23-2015, 06:22 PM   #117
lowrodderchev
lowrodderchev's Avatar
any progress?
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-24-2015, 10:05 AM   #118
BIGglaSS
BIGglaSS's Avatar
Well, I'm in the same boat now. Trying to figure out whether to tilt the rear end carrier or not. My engine ended up higher than the rear end. Your step notch is higher than mine. If I lower the engine more, the transmission pan will drag when aired out. If I raise the engine to be able to air it out, I will have to modify the floor pan, and tilt the rear end carrier even more to get the u-joints in spec. Keep us posted!
Old 06-24-2015, 03:43 PM   #119
ptc
ptc's Avatar
Watch this video... it explains everything you need to know about angle of the dangle.
https://www.youtube.com/watch?v=KZ-m9ov3wYM
Understand why 'angle is required'.... for the driveline u-joint cap needle bearings to operate properly they need only a minium of a 1* angle to keep them rotating. If there is no angle the needle bearings inside the caps do not turn and they will deform quicker.
When you lower vehicles there are many mods that have to take place to make everything work right as you are finding out.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 06-24-2015, 08:33 PM   #120
samples45
samples45's Avatar
[QUOTE=lowrodderchev;7219211]any progress?[/QUOTE
Ive done a little more work on the frame! I get some pictures up later or tomorrow! Ive been smoothing out all the seams on the cab for awhile! It takes forever!
Old 06-24-2015, 08:37 PM   #121
samples45
samples45's Avatar
Hey buddy, i got my carb flange level so my trans is pointed down the 3 deg, since im using the corvette rear end i thought i might as well use the tourqe bar that comes with the vette and when its bolted to the rear and bolted to the brackets up front the rear end wont move up i guess like a normal rear would? so my drive line has a slight down hill slope towards the rear end.. i hope that will work because thats whats gonna have to happen! lol after i thought about it in the stock vette the tourqe bar bolts to the transmission and the rear end so the drive train didnt move in the vette and its not gonna move on the truck. hope it works
Old 06-27-2015, 10:27 AM   #122
BIGglaSS
BIGglaSS's Avatar
With rough measuring, it looks like my engine will be down 2 degrees. I will point the pinion up 2 degrees to match. The u-joint working angles should be within a half degree of each other for smooth operation. Is there enough flex in the batwing bushings if you raise the torque arm to change the pinion angle?
Old 06-30-2015, 12:05 AM   #123
samples45
samples45's Avatar
Yeah there is..on the vette the torque arm is bolted to the trans and the rearend..I might need to do some reading and see what the angles and stuff are.. because if the torque arm was bolted to the tail shaft and the rearend i wonder how they offset them at all?
Old 06-30-2015, 01:51 PM   #124
_Ogre
_Ogre's Avatar
nice progress
did you start your build this year or just start posting pics?
shop air compressor timer
Old 06-30-2015, 05:38 PM   #125
Kim57
Kim57's Avatar
I saw your question in Ogres' thread and answered it there.
Here are some pics on how I did my cowl vent.
Kim
My build thread
