Old 02-25-2015, 10:17 PM   #1
samples45
samples45's Avatar
1955 (2nd gen) first timer..
Well after reading everyones build i think ill start my own.. My name is Cameron, Im 23 years old from good ole Oklahoma. I have a 1955 chevy 2nd gen ill upload some pictures once i get the size of the pictures right keeps telling me they are to large! anyway looking foward to all the help from you guys lord knows im gonna need it!
samples45 is offline   Reply With Quote
Old 02-25-2015, 10:18 PM   #2
samples45
samples45's Avatar
Re: 1955 (2nd gen) first timer..
Looks like i got one to upload and didnt even mean to!! lol!
Old 02-25-2015, 10:41 PM   #3
samples45
samples45's Avatar
Well here are the pictures of the truck when i first got it..All four inner and outer cab corners were rusted, the floor pans, all 4 bottom pillers..and someone tried to do some body work on it years ago it looked like.
Old 02-25-2015, 10:50 PM   #4
samples45
samples45's Avatar
Heres some more
Old 02-25-2015, 10:56 PM   #5
samples45
samples45's Avatar
I wasnt sure what to do about the chassis so i went out of order you could say on this.. lol I started to take care of some of the rust.. now remember this is my first time to do any of this stuff so dont make fun! Im learning as i go and if i mess up i just re do it.. so if you see ANYTHING wrong or not right please let me know so i can go back and do it right.. Its the only way to learn!
Old 02-25-2015, 11:05 PM   #6
samples45
samples45's Avatar
now where i stand today with the build. I got a 1990 c4 donar car, pulled the motor/trans out to use on this truck and also the front and rear suspension.
I dont have pictures of the motor ill get some on here though!
Also still working on this picture thing! they seem to be to small now..ill get it worked out!
Old 02-26-2015, 09:29 AM   #7
Kim57
Kim57's Avatar
Welcome.
Looks like you have a real good start on it.
We were all new at this once. Just keep at it and things will get easier.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-26-2015, 04:54 PM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
Good start there buddy. I met you on the other site. I'm Bam55 on that site. Its nice to have you over here. Keep those pics coming.
Kabwe is offline   Reply With Quote
Old 02-26-2015, 05:06 PM   #9
samples45
samples45's Avatar
Originally Posted by Kim57 View Post
Welcome.
Kim
Thanks Kim!
Old 02-26-2015, 05:08 PM   #10
samples45
samples45's Avatar
Thanks man! Yeah I gotcha! Ill get tons of pictures up so yall can guide me when I need it!
Old 02-26-2015, 08:53 PM   #11
samples45
samples45's Avatar
got the k-member in just for mock up..im not gonna be using these wheels and tires but do they look good under the fender? are they to far foward?
Old 02-26-2015, 11:28 PM   #12
Kim57
Kim57's Avatar
Looks pretty good to me.
Kim
My build thread
Old 02-26-2015, 11:31 PM   #13
samples45
samples45's Avatar
Kim
Thanks kim! next im gonna get this thing welded in and boxed up.. I also gotta figure out how im gonna do upper shock mounts since im wanting to go with coilovers
Old 02-27-2015, 12:59 AM   #14
Flames97
Flames97's Avatar
Builds looking good. Nice job
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 02-27-2015, 01:03 AM   #15
samples45
samples45's Avatar
Thanks buddy! I'm figuring it out!
Old 03-02-2015, 11:54 PM   #16
samples45
samples45's Avatar
Got some work done on the truck today. I went ahead and put some tack welds on the C4 k-member and set the truck on the ground.. Waiting to see what im gonna do about wheels before i do a final ride height..
Old 03-03-2015, 12:24 AM   #17
Hawkerdriver
Hawkerdriver's Avatar
looking good I'm fairly new to all this as well I am a few weeks behind you I just drug mine home this weekend.. Subscribed..
Hawkerdriver is offline   Reply With Quote
Old 03-03-2015, 12:30 AM   #18
samples45
samples45's Avatar
Thanks man!
I'm having fun though! I know it doesn't look like it but I have tons of time in that cab! Maybe because it's my first time, but it took me a solid week to get my dash smoothed out! Lol it took a month or longer to replace all the sheet metal and I still have many more hours just to have it in primer.. Hope to see your build!!
Old 03-03-2015, 12:44 AM   #19
hp1957
hp1957's Avatar
Cool to see another C4 build ! Rec center your k-member, bolt your upper & lower control arms on, bolt steering rack down, set the top of x-member where the upper control arms bolt up at 14 degrees at ride height & rack and pinion arms to the lower control arms level at ride height also. Your mock up w 17in wheels are ok. If you decide on bigger wheel than 20inch, should purchase them first to set your ride height.
Harvey
1957 Chevy Stepside
1958 GMC Fleetside C4 build thread: http://67-72chevytrucks.com/vboard/s...=535686&page=6
hp1957 is offline   Reply With Quote
Old 03-03-2015, 12:48 AM   #20
Hawkerdriver
Thanks man!
Glamorous Gena is my build..
Old 03-03-2015, 01:12 AM   #21
samples45
samples45's Avatar
Harvey
1957 Chevy Stepside
Thanks Harvey! Are you saying the A-arms at 14 degrees? Or the x member where the arms bolt to at 14 degrees?
Old 03-03-2015, 09:21 AM   #22
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 03-03-2015, 11:45 PM   #23
samples45
samples45's Avatar
Sorry man just saw this! Im gonna go find it!
Old 03-03-2015, 11:46 PM   #24
samples45
samples45's Avatar
Looks real nice.
Kim
Thanks kim!
Old 03-04-2015, 12:43 AM   #25
hp1957
hp1957's Avatar
Cameron, set the top of x-member where the upper control arms bolt up at 14 degrees at ride height & rack and pinion arms to the lower control arms level at ride height also.
Harvey
1957 Chevy Stepside
