#51 |
![]() ![]() Join Date: Aug 2013
Re: 62 Front SwayBar Installation
A follow up on the torsion bar keys and how I raised them almost 1"
I had a chance to takes some pictures of how I gained some ground clearance.... so here's some pictures. The bushing was sourced from center axle on some throw away castor. A friend sourced his at the local bearing supply in bronze under $10. The picture shows the dimensions with my example. You will also see the skid plate I attached to the X pipe out of 1/4" plate to help protect every thing a little further. As you can see there is a speed bump that hates me in my driveway, but the keys haven't scraped ![]() |
#52 |
![]() Join Date: Oct 2006
Just outstanding thanks
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#53 |
Who Me?
So you removed the piece in the 2nd picture to get it higher off the ground.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#54 | |
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#55 |
#56 | |
#57 |
Your truck looks awesome!!!
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
#58 |
#59 |
Hey Joe and Doobie,
what shocks are you guys running front and rear? |
#60 | |
#61 |
Moderator
![]() ![]() Join Date: Aug 2011
Very, very nice job Joe!
#62 |
#63 |
#64 | |
Here's the pictures I have, hope you can see enough....just so you know I'm an automatic and relocated the trans mount to the back. I trimmed flush the bell housing crossmember/mount which opened up a straight shot back. Joe |
#65 | |
#66 |
Who Me?
Heck with the sway-bar! Look at that exhaust system!! Sweet
#67 |
#68 | |
60-66 Nut
With a manual trans and the original bellhousing crossmember in place, you will not be able to run any of the car headers. IMO your best bet is the Hedman #69260 headers. They are listed to fit '55-'65 trucks. No spark plug issues. In fact these will work with angle plug heads.
#69 |
Moderator
A bit pricey for some, however these would give your X-pipe some clearance:
http://www.spintechmufflers.com/x-pi...s/cat_126.html
#70 | |
#71 | |
Joe |
#72 |
Thanks for the info Joe! Beautiful job on the truck.
#73 |
#74 |
Hey Joe,
I got my sway bar installed and finally getting a chance to run around with it a little bit. I had to replace a brand-new motor with another after the guy at the exhaust place wiped out the cam revving it up!!! (He wouldn't take ownership of it though) The ride difference on this with the sway bar is remarkable. Much more stable and much less vehicle sway! Anyway, I am getting a bit of rubbing of the right front tire on the side of the sway bar. I have the old tires on there that have quite a bit of bulge until I can get the axels swapped out and converted over to 5 lug. Did you have any rubbing issues? Also, what kind/size of wheel are you running and do you remember the offset? Tom
#75 | |
![]() Anyway I haven't had a rubbing issue on the swaybar...I run 15x7" front wheel with a 3.5" backspace. The tire is a 225/65/15 and its a BF Goodrich "G" force tire with a stiff sidewall to also help with its handling. |
