#26 |
Re: 62 Front SwayBar Installation
Your truck looks great...be sure and give us the "full report" on the test drive. I bet that thing is going to ride like a dream....
Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
#27 | |
![]() ![]() Join Date: Aug 2013
Its still raining with 50mph gusts..... I'm excited about the improvement and tomorrow is the break in the weather....so they say |
#28 |
This is great. Thank you for the information.
Waiting for ride update!! John |
#29 | |
![]() Quote:
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
#30 |
Well the moment you waited for....Handles Great !...Went 25 miles around the back roads cornering and not letting off the gas in fear of losing any control. Not that I will compete in a autocross, but its definitely a BIG improvement with money/time well spent....Oh and in the 3rd picture I did an evasive maneuver to avoid the puddle with good handling....yeah I know but the wheel wells are still clean.
![]() So here's some action photos....well just proof I did at least drive it... LOL Joe. |
#31 | |
#32 |
![]() Join Date: Oct 2006
I will have to put this on my "To Do" list... thanks again
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#33 |
#34 |
Hey Joe,
Thanks again for this post. I got mine in from Summit for about $179 and it was here in Central California in a couple of days. Can't wait to get it installed...got to get the engine in this week and then I can start cranking down the torsion bars to adjust the final ride height! Weathers been nice...you had the truck out at all? Any final thoughts? Tom
#35 | |
#36 |
Hi Joe so how about an update , how has the sway bar held up ?
#37 |
![]() Join Date: Feb 2014
Awesome write up, well documented. subscribed for updates. Great job on the truck!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
#38 |
![]() Join Date: Mar 2014
I noticed your front end looks pretty low (looking at the space between bottom a-arm and frame).. did you do anything special or just lower by turning down the torsion bar adjustment bolts?
#39 |
All is well, The truck handles respectively well and no issues with the installation ...Been thinking of a rear sway bar installation, as most torsion bar owners will agree that there is no direct bolt on available for the rear either. What I thought I could make work is hindered by the exhaust going under the rear end. So since it's not a safety issue I will eventually find the right combo and post about it
![]() As far as the ride height, it's sitting on 225/65/15 front with 2.5" drop spindles and the rear is 255/70/15 with 5" drop springs and 1" lowering blocks. I cranked the torsion keys until the A-frames were about level to the ground. |
#40 | |
#41 | |
#42 |
Oh man, the inspiration your truck is giving me!!
I'm pulling my front clip off right now and pulling my old 283 to put the new crate 350 in. I'm curious what headers you're running with the torsion bars...looks like they fit pretty well. ![]() |
#43 | |
#44 |
NVS-C10...Your welcome...I'll try to get some better pictures...
#45 | |
#46 |
Summit racing is where I got these http://www.summitracing.com/parts/pt...model/chevelleAttachment 1399973
#47 |
Wow your undercarriage is cleaner than the outside of my truck
-Chapa 65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear. |
#48 | |
But Found Her 25yrs Later!
My 65 is on a 62 frame. What a simple fix to get those keys up a little higher.
#49 |
I agree !!! Thanks Joe
#50 |
