#76 |
![]() Join Date: Mar 2004
Re: 4x4 LS cross member
Very interesting. Were his blazers 4x4?
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 Last edited by GMC-YA68; 11-06-2015 at 11:02 AM. |
#77 |
![]() Join Date: Oct 2011
#78 |
https://issuu.com/truckandcarshop/docs/ts_47-59_13_web
Thats a link to the "the Truck Shop" catalogue and like mentioned before, the crossmembers are on pg 93 |
#79 |
i have to order this..subscribed
#80 |
#81 |
If you use the dirty dingo cross member most header don't fit I had to cut and re work the Dough Thorley headers I bought. I tried block hugger type header and had fitment issues as well. or stock manifolds will fit 2.
the main issue is the the headers are made to fit 2 wheel drive truck. the cross member on 2 wheel truck pushes the engine up 1.5" higher than 4 wheel drive. |
#82 | |
#83 |
I have a 71 4X4. check out my build thread I have pictures. 71 4X4 frame off Restoration
#84 |
Its here.
#85 |
Very cool in deed.
#86 |
#87 |
Boosted Member
Put the holes wherever you want/need for your build.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#88 |
Done thanks guys.
#89 |
Done ?. I see a couple bolts missing. I wedged mine up to the top of the frame to get it as high as I could to help out with the headers. your installation looks good. Are you using stock manifolds or headers.
#90 | |
#91 |
Let us know how the headers fit.
#92 |
#93 |
Had email issue just got it fixed. interesting about the issue you have with your headers. mine clear the shackles and hardware.
#94 |
#95 |
All about them K’s
![]() Join Date: Jun 2014
Anyone have an update on the 47-59 v8 swap crossmember into a 67-72 4x4 LS swap? I’m readying my self for the swap for my K20 and stumbled across this thread. Looks like a very cost effective way to approach this. I’m not honestly crazy about the dingo or pacfab setups, as I don’t plan to lift my truck right away, maybe in the future but not now.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#96 |
I'll add my two cents. I used Dirty Dingo mounts for my '70 K10. I have a Dana 44 up front. Overall I like the mounts (the newer ones have holes for front brake lines that run through the frame). I have a 4" lift and have loads of room between the mount cross member and the pumpkin.
But the two major problems I've had: First, I can tell my LS heads are going to be really tight against the firewall even after pushing the engine all the way forward. Second, headers. I sent back the first pair I bought because of fit. I now have mid-length Doug Thorley headers and still had to modify the header slightly on the drivers side to fit inside the frame. An extra inch or two of engine clearance up above the frame would have made all the difference. |
#97 |
I took a chance and used the Jegs cross member that was posted earlier. I had the body off the frame so hopefully it all works but the cross member is in and engine set. I will take some photos. Btw 1971 4x4
#98 | |
All about them K’s
Building my engine now and trying to get everything together for this swap.
#99 |
Cross member in. I am at stock height right now and there is at least 2 inches from cross member to front diff. The bracket hit right at the bumper stops so I had to remove them but I wanted the cross member back some for my low mount AC. Have to mount the compressor yet but there is enough room with the motor mounts back. I used adjust mounts
#100 |
All about them K’s
Thanks for the pictures, I think I’m gonna go this route. so is your transmission and transfer case in the stock 67-72 position? I don’t want to move them so I don’t have to modify the driveshafts at all.
