Old 03-01-2015, 05:59 PM   #1
First c10
First c10's Avatar
4x4 LS cross member
Ok I asked this in the 4x4 section with no response. Can anyone shed some light on which cross member to use.
This is the original thread with the links.
http://67-72chevytrucks.com/vboard/s...d.php?t=661468
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-02-2015, 01:16 AM   #2
GMC-YA68
GMC-YA68's Avatar
Re: 4x4 LS cross member
I remember a thread of someone using the PF member and had to barely trim it for clearance. Not sure about the DD.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 03-03-2015, 02:02 AM   #3
First c10
First c10's Avatar
Thanks for the comment!
Anyone else have a history with one of the LS cross member mounts in a 4X4?
GO GO!!!
Old 03-03-2015, 10:00 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
I used the dirty dingo setup. I used it because i was in a hurry, and didn't feel like fabbing anything up.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-03-2015, 01:01 PM   #5
First c10
First c10's Avatar
Wasted, did you have to move the engine forward at all to clear the cab? I am basically doing the same thing you did to your 69lwb.
GO GO!!!
Old 03-03-2015, 04:30 PM   #6
Wasted Income
Boosted Member
I initially positioned it to clear the factory AC compressor...so it's really far forward in the frame. There is a TON of room between the engine and firewall. It's actually kind of nice for working on stuff back there.
Turbo diesel
Old 03-04-2015, 12:34 AM   #7
GMC-YA68
GMC-YA68's Avatar
I read that the PF won't work with a stock height truck. The mount hits the oil pan. It will fit but it leaves no room for suspension travel. True???
-Keegan-
Old 03-04-2015, 02:31 AM   #8
First c10
First c10's Avatar
Did you relocate the crossmember or just slide the dd motor mounts forward?
Gmc,
from all I have read either mount will NOT work well with a stock height truck. I think minimum 2" lift is needed.
GO GO!!!
Old 03-04-2015, 02:35 AM   #9
First c10
First c10's Avatar
I still don't understand why the motor sits so low in a 4x4 Compared to a 2wd. Or at least that is what most have said in there builds.
GO GO!!!
Old 03-04-2015, 04:39 AM   #10
ls1nova71
ls1nova71's Avatar
I was thinking it doesn't sit lower, but that the pumpkin on the axle would hit the pan? Could be wrong though. Would an f body pan help anything, you think?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-04-2015, 07:04 AM   #11
GMC-YA68
GMC-YA68's Avatar
I've read the pan seems to be ok. Fbody pan would give me peace of mind but it's the cross member that actually hits on the diff. Everything I read says to install a 2" lift.
-Keegan-
Old 03-04-2015, 11:13 AM   #12
Wasted Income
Boosted Member
I did have to do some grinding on the DD mount to clear the truck oil pan. Kind of annoying grinding on laser cut parts...
Between being able to slide the DD slider mounts, and sliding the crossmember where I needed to in the frame, I put the engine exactly where I wanted it, then drilled new holes in the frame.
Turbo diesel
Old 03-04-2015, 01:26 PM   #13
First c10
First c10's Avatar
Great thank you! did you get the crossmember powder coated from DD or had it coated after you test fitted it? That would suck to have it powder coated first and having to grind on laser cut powder coated parts!!!
thanks for the info and ideas guys
Scott
GO GO!!!
Old 03-04-2015, 01:39 PM   #14
First c10
First c10's Avatar
FYI, this is some information sent to me from cmabolt "Thanks Chris"
Originally Posted by cmabolt
Hello, I just wanted to write you regarding your interest in the LS crossmembers. I didn't want to highjack Dwilber's Build thread.
I used the pacific fab crossmember only because Dirty Dingo didn't have theirs on the market yet for 4x4's. Pacific Fab's crossmember is an extremely well built piece. Very strong. I put it in place and aligned it where the original motor mounts were. I then dropped the cab and found that the rear passengers side valve cover was hitting the firewall. I did some research and found that others had moved the motor forward to make some space between firewall and motor. I moved my crossmember forward 2" which gave me nice clearance in front of the firewall and plenty of room up front for an electric fan.
The dirty dingo crossmember looks to be well engineered as well. I think it's cheaper too. If I we're to do it again, I would probably go with the dirty dingo crossmember. One benefit is that you can actually drop the center section of the crossmember to remove the oil pan. This is not available on the pacific fab crossmember.
In conclusion, they are very similar in design, but I am sure dirty dingo has the advantage as they probably engineered theirs to take advantage of the shortcomings of the pacific fab unit. That's what I would do. If you plan to do headers or use a manual trans with hydraulic setup see my build thread or 69Crash. We both used pacific fabs crossmember. 69crash used an automatic and I used a manual trans. I used headers and he used manifolds. A ton of info on both builds.
Good luck, I hope this helps you make a decision.
Chris
GO GO!!!
Old 03-04-2015, 02:32 PM   #15
First c10
First c10's Avatar
OK so price before shipping for each
Pac Fab 419.00 Shipping $16.74 but are 50 minutes away from me.
DD 455.00 Shipping $18
thoughts???
GO GO!!!
Old 03-04-2015, 03:56 PM   #16
Wasted Income
Boosted Member
Scott
Oh, that's my other gripe. I paid extra to have the DD stuff PC'd by them before shipping.
What a joke. That **** started flaking off the sharp edges right away....I wish I'd just taken them to the same guy that did the frame...probably wouldn't have cost me any more, for a far superior job.
Turbo diesel
Old 03-04-2015, 04:06 PM   #17
GMC-YA68
GMC-YA68's Avatar
thoughts???
So are you going to lift it, or buy the member and see where the engine sits? I'm in the same boat, you can go ahead and be the guinea pig! LOL
-Keegan-
Old 03-04-2015, 05:20 PM   #18
First c10
First c10's Avatar
Wasted, I figured you were going to say that!!!
Gmc
Check out my build thread in my signature. Yes I plan to lift it 4 inches. I talked to John at Pacific fabrication they are about 50 minutes from me. I may go talk to them and check out the crossmember before I buy anything. I am thinking about buying the pacific fabrication crossmember and cutting it or adding a removable center section under the oil pan.
GO GO!!!
Old 03-05-2015, 12:20 AM   #19
SDfarms
SDfarms's Avatar
Scott i would go with dirty dingos cross-member if you are not able to build your own it would be quite simple. Myself got the pacific fab because it was dang near 150 cheaper... Big mistake... Both me and chris (Reno build) experienced the motor mounts not lining up, he didn't have it as bad as i did i had to weld an extension to the top on both sides. Once i got it bolted in i noticed one mount was twisted. I would not want anyone to have something like this.
SDfarms is offline   Reply With Quote
Old 03-05-2015, 12:37 AM   #20
Daaaanz67
Subbed
Daaaanz67 is offline   Reply With Quote
Old 03-05-2015, 01:21 AM   #21
First c10
First c10's Avatar
Thanks Lance for the info. I was also thinking of possibly making my own. Do you know of anyone that has?
GO GO!!!
Old 03-05-2015, 02:39 PM   #22
JJH Jimmy
JJH Jimmy's Avatar
I built my own. Mostly because the pacific fab one was the only thing available and i didn't like the price tag or the looks of it. It was actually pretty simple i just set the engine in the frame where i wanted it to go and built it from there. There is a couple more pictures on the first page of my build thread.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 03-05-2015, 10:38 PM   #23
GMC-YA68
GMC-YA68's Avatar
Going to look at your build thread now but are you lifted?
-Keegan-
Old 03-05-2015, 10:57 PM   #24
JJH Jimmy
JJH Jimmy's Avatar
Yes. I have a 4" lift. But I am pretty sure that it would clear the pumpkin even if it was not lifted because of how far back the engine sits with the 4l60e and the 205 in the stock position.
1985 Chevy K20
1994 GMC Yukon
Old 03-05-2015, 11:41 PM   #25
First c10
First c10's Avatar
Hey jimmy any more pictures installed?
GO GO!!!
