Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 11-14-2015, 02:08 PM   #1
clang6
Looking for a tie rod bar
I need a 69-72 4wd tie rod bar. Mine is bent and I need to replace it.
clang6 is offline   Reply With Quote
Old 11-14-2015, 10:03 PM   #2
clang6
Re: Looking for a tie rod bar
This the part I need. 69 Blazer
Old 11-14-2015, 10:30 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Looking for a tie rod bar
hard to tell from the pic but it looks like you have an open knuckle front diff. 69 was closed knuckle with drum brakes, 70 was open knuckle drum brakes, 71 on up was open knuckle disc brakes. which one do you have ? i have one from a 72 low mileage blazer, $100.00 shipped in a pvc tube.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 11-14-2015, 10:54 PM   #4
clang6
Good question, however, I have no idea. How can I tell? We do have disc brake kit on it.
Old 11-14-2015, 11:00 PM   #5
jerry moss
Born Psycho
jerry moss's Avatar
there is a number stamped in the axle tube that will tell the year, axle ratio etc. i assume you are not the original owner so best have the number de-coded to figure out exactly which diff you have, that will also help you later on when replacement parts are needed-bearings, seals, axle u-joints, etc.
jerry moss
Old 11-15-2015, 03:29 PM   #6
clang6
Correct, not the original owner. The axle is stamped 44-5F. Yes, it looks like open knuckle.
Old 11-15-2015, 06:47 PM   #7
jerry moss
Born Psycho
jerry moss's Avatar
thats just a casting number, the numbers you are looking for are stamped into the axle tube--and are very small.
jerry moss
Old 11-15-2015, 07:39 PM   #8
ajviper
ajviper's Avatar
1969 Blazers had an open knuckle from the factory to my understanding.
Chevy Runs Deep.
1956 210 LS1 TH350 3.31 Posi 12 Bolt
1969 Z/28 5.3 T56 3.73 Posi 12 Bolt
1973 Nova SS 355 TH350 2.73 Posi 12 Bolt
2000 K2500 Suburban LS 6.0 4L80 3.73 G80
2005 K2500HD CCSB LS 6.0 4L80 4.10 G80
2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic
ajviper is offline   Reply With Quote
Old 11-16-2015, 08:32 AM   #9
1rippen6
I should have one I will look tonight
1rippen6 is offline   Reply With Quote
Old 11-16-2015, 10:26 PM   #10
1rippen6
Sorry for the crappie pictures the best I can do at night
