Old 10-26-2015, 03:56 AM   #26
GTSideSwipe
Re: Blood, Sweat, and Curses
I looked up that kit and found quite a board on here and the first post on the 2nd page has the same kit with 20x8.5s in the front and 20x10s in the rear. If your looking for a little bit more side wall then you could go with 18s.
http://67-72chevytrucks.com/vboard/s...=471442&page=2
I also found a image on Google that has 16 inch rims with the look I'm going for.
GTSideSwipe is offline   Reply With Quote
Old 10-26-2015, 04:05 AM   #27
JSF3RD
Yeah I've read through that board. Most of them that have 20" look like a low pro tire and I'm looking for a little more wall. I guess ill just have to step down to 18" to not rub.
JSF3RD is offline   Reply With Quote
Old 10-26-2015, 04:25 AM   #28
GTSideSwipe
Here are some images of 16" examples. Will find some 18" ones now if you like.
Old 10-26-2015, 04:37 AM   #29
GTSideSwipe
Some 18"
Old 10-26-2015, 05:17 AM   #30
JSF3RD
Well, I like the dimensions of the 255/55. I know they're readily available in18 or 20. Just thought the 20 would have a little better aesthetic.
But I have to make some hard turns to get it into its parking spot because that area is actually to the side of my driveway. I don't want to have to constantly touch up my wheel wells from the rub.
Old 10-26-2015, 06:40 PM   #31
JSF3RD
Got the radiator and fan shroud out. Turns out the radiator pan is toast too.
Someone please tell me their frame has this little flair by the fuel pump.
Sorry the light isn't better.
Old 10-27-2015, 01:03 AM   #32
JSF3RD
Well, I looked at every other 67 build thread and it seems to be the norm.
Does anyone know why it's like that?
Old 10-27-2015, 09:58 AM   #33
Xeen
Xeen's Avatar
I don't know why they did that but they are all like that.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 11-13-2015, 07:45 PM   #34
JSF3RD
I know it's been a few weeks, but I have got quite a bit done.
I got the bed pulled off and the wheel tubs off the bed. Now I'm not sure what to do. I had a heck of a time just getting the tubs off because the square holes for the carriage bolts kept striping. I had to cut a lot of the bolts. I know the floor is toast but I'm not sure I can save the sides.
Can I even mount it to a new floor with the holes messed up, or is this a "time for a new bed" situation.
Old 11-13-2015, 07:55 PM   #35
Xeen
Xeen's Avatar
If you show pictures of the damage with the question we can help you better.
Old 11-14-2015, 12:21 AM   #36
JSF3RD
Well, the largest problem is that a lot of the bolts that hold the floor to the bedside are going to have to be cut. Some I can't get to without cutting the bed supports and bed front to shreds.
Also, if the carriage square in the bedside are rusted out to the point that I have to cut them, is it even possible to reuse them.
This is one of the bed mounts I had to cut. I'm afraid they're all going to be that stripped.
Old 11-14-2015, 12:22 AM   #37
JSF3RD
I'll try to get some better pictures tomorrow.
Old 11-14-2015, 12:51 AM   #38
swamp rat
swamp rat's Avatar
The good news is that little space you have to work with is paved, mine isn't.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-14-2015, 11:00 AM   #39
Xeen
Xeen's Avatar
Don't worry about damaging the bed floor it can be welded, just try to do as little damage as possible.
The repop bed floor is $1,000.00 so keep that in mind.
The front panel can be replaced cheap.
The bedsides are going to have to be a judgement call after you get it completely apart and down to bare metal so you can evaluate how much damage there is, it may be cheaper to replace them with repops than the cost to repair them.
The repops are about $500 apiece.
Old 11-14-2015, 12:31 PM   #40
JSF3RD
Yeah, im not worried about the floor because it's got a lot of places where its rusted through. If I tried to patch it it would be about 75% patch.
I think my best chance to save the sides is to sacrifice the front and floor.
Plus I think it originally had a wooden floor. Haven't decided if I want to go back to wood or redo metal.
Also, are the bed supports attached to the bed floor?
Old 11-14-2015, 04:02 PM   #41
Xeen
Xeen's Avatar
There are floor support strips that are welded to the floor but those are separate from the support crossmembers.
Old 11-15-2015, 12:49 AM   #42
JSF3RD
That's what I thought, but I think one of the POs did something to the crossmembers cuz they are not moving. IDK, maybe they've just rusted to the bottom. I didn't see any welds, but at this point I wouldn't be surprised by much.
Old 12-02-2015, 07:43 PM   #43
JSF3RD
Well, once again I'm in a dilemma.
I got the bed pulled off as one piece. I started to take it apart and realized that its not coming apart in any useful manner.
So now I have to decide if I should try to keep useing this one for a while, or go ahead and sell it and start on a new one.
Old 12-03-2015, 12:54 AM   #44
JSF3RD
Well, in the interest of getting the truck back up and running, I've decided that I'm gonna just weld up the biggest of the rotted spots. Grind it smooth, rattle can it, and let it ride till it either falls apart or I get around to doing a full frame off restoration.
I just have to keep reminding myself that this is damage control, not making it a show truck yet.
Old 12-03-2015, 03:19 AM   #45
swamp rat
swamp rat's Avatar
Bedsides have 2 or 3? bolts on the underside going up into the rear of the bedsides around the stake pocket area, kinda hard to see them if its a little dark, also the rear steak (yea i'm hungary LOL) pocket is welded on each side to the floor, once ya use a grinding wheel on the welds and tet the hidden bolts out, then the rest of the visable bolts then you only have to fight 40 years of rust as you wiggle the pieces apart..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-03-2015, 03:42 AM   #46
JSF3RD
Well all my carriage holes are stripped and the PO tack welded every bed support to every spot it touches the floor. And my spare tire bracket is bolted by one of the bolts that are inside of the bed support.
Also, I can't even get to the ones in the front corner that hold the front/side/floor together.
There were many curses today.
Guess for now I'm just gonna make lemonade, and save for a new setup down the road.
Old 12-03-2015, 04:43 AM   #47
swamp rat
swamp rat's Avatar
Unbolt the bed from the frame and scoot it back a little to gain access to the front headboard bolts, support it with some timbers if need be..
All the bed supports are welded from factory I think, i have seen lots of beds that way with the steel floors, the wood beds are loose.
One tip i have read on this forum that i have not tried myself is that because the carriage bolts are pretty small and if they are rusty you can just tighten them until they snap off and that is suppose to keep the square head from spinning and hogging the square holes out.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-04-2015, 01:54 AM   #48
JSF3RD
Yeah. I just don't think I can get it apart and have anything useful when I'm done. It'd just be reduced to patch panels by that point.
And if soaking all those bolts with liquid wrench and wd40 didn't get them apart, I don't think they're gonna come out.
Never heard of the tightening thing before. Guess I can try it. They're all stripping anyway. What's the worst that could happen?
