Old 12-25-2015, 11:19 PM   #76
Boog
laying low
Boog's Avatar
Re: Pace performance fitech fuel injection
You fellas know about the fuel lines being different diameters don't you? The 6 cylinder has a 5/16" single line only and a later V8 has a 3/8" feed line and a 1/4" return line from the sending unit to the fuel pump. And as far as I know each sending unit will fit in either eec tank or non eec tank. Just an FYI when planning your fuel system.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-26-2015, 12:26 AM   #77
Lattimer
Lattimer's Avatar
Yup.
My truck was originally a 6-cylinder, but everything has been replaced. i did custom fuel lines tank to carb, new tank, and new sending unit.
I agree, sending units all fit any of the tanks. You can use the one with a return pretty easily to add a return to the in cab tank. You can get sending units with 5/16 or 3/8, and 3/8 ones with or without returns. The sending unit that was in my truck when I got it was 3/8 and had a capped off return. When it died I replaced it with a 3/8 without the return. That was after I had replaced the tank.
If I had known then what I know now I would have bought an EEC tank and made all of this easier.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-27-2015, 09:36 PM   #78
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
With the cost of other brand units, I figured I'd wait until my carb started giving me issues, but for this price I might just bite now.
Although, I may just wait and see about the new 400hp unit.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-28-2015, 12:59 AM   #79
steveo3318
steveo3318's Avatar
Ok guys I just ran a test. I hooked my return line up to my shop air and put 10 psi of pressure to it and as it was filling the tank I heard it start hissing. So I crimped the hose off to hold pressure to find the hiss. Sure enough my one way vented cap will also vent high pressure out. Needless to say it takes a good amount of volume and pressure but it will vent. This is good news to me for not having to do another vent line. Another good thing is if it builds that much pressure I will surely hear it. I am going to run the command center vent to my factory tank passenger side vent that's already under the hood and run it as a vent IN only system and only out if it exceeds over 5 psi. I feel like it will be good
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 12-28-2015, 01:09 AM   #80
Lattimer
Lattimer's Avatar
Let us know how it works out!
Shawn
Old 12-29-2015, 03:34 PM   #81
Tomahawk30
Tomahawk30's Avatar
So would the inline pump kit that they offer work with the factory in-cab tank in a 72 (vented, has a return port on the sending unit assembly)? Do the electric pumps have enough draw to lift the fuel through the top of the tank? I have no experience with electric fuel pumps.
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline   Reply With Quote
Old 12-29-2015, 03:53 PM   #82
Lattimer
Lattimer's Avatar
From what I have heard, it will work, but the pump will be short lived.
Shawn
Old 12-29-2015, 04:40 PM   #83
Big Kev-O
Big Kev-O's Avatar
It works fine. See post #22 for a picture of the fuel sender I modified so I could use the FiTech Inline Fuel pump Kit. I added a 1/2 inch stainless steel pick up to the factory fuel sender and used the factory pick up as a return. Bending the line, brazing it to the sender and installing it into the tank was not easy but is possible. It probably would have been easier to empty the tank, drill a hole in it and use a plate over the hole with rubber gasket, bulkhead fitting and pickup tube. I didn't want to drain & remove the tank. OR you could use a factory sender that has a suppy and return if you can find one(I didn't know the 72 had a vent line).
The FiTech kit uses -10AN push-on fittings ans 1/2"I.D. hose to connect the supply line to the prefilter and to the pump inlet. The pump primed instantly even with a near empty tank. It looks to be a high quality Walbro that has been rebranded with FiTech's logo. I'm sure it will provide years of trouble free operation. FiTech was in the OEM EFI buisness for along time before starting their aftermarket EFIs so I doubt they would sell you a junk pump.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 12-29-2015, 06:46 PM   #84
Z10
Z10's Avatar
The 72's have a vent port on the top of the tank.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-29-2015, 07:45 PM   #85
Tomahawk30
Tomahawk30's Avatar
Yup, my tank has a vent off the top on the passenger side, the short one going to the filler neck on the driver side, and then the sending unit has the feed line and what I assume is a return line that is just capped on the outside with a plugged chunk of hose.
Old 12-29-2015, 08:47 PM   #86
Z10
Z10's Avatar
Are you currently using your mechanical fuel pump? If so, fill the command center (surge tank) from your mechanical pump. The surge tank has a high-pressure pump inside which will feed the TBI.
Hope that helps.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-29-2015, 08:50 PM   #87
Tomahawk30
Tomahawk30's Avatar
Hope that helps.
Yes, I'm running a mechanical pump now. Haven't ordered an EFI yet, just getting an idea of my options. I know the Command Center is the obvious choice, but I figured I'd see how feasible the inline pump would be without the Command Center. I'm just excited that the feedback has been so good on the performance so far, and the price have dropped to reasonable levels all of a sudden!
Old 12-29-2015, 08:58 PM   #88
Z10
Z10's Avatar
If your mechanical pump is working fine, use it. It will save you some work. Although we fabricated our own surge tank (Command Center)it functions just like it. I've been operating this set up for over 7000 miles on my 72 utilizing a FIRST TPI EFI. If the FiTech Command Center been available at the time, we would have gone that route. Still would have used the FIRST system.
I have purchased the FiTech TBI unit and Command Center to go on my 69 Camaro and will be using my mechanical pump. The FiTech parts look first rate.
You can see some of our work on my build thread in my signature.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 12-29-2015, 08:59 PM   #89
67 chevelle
67 chevelle's Avatar
Having done a few efi systems , this one looks impressive , compact size , anular discharge , and a built in pressure regulator , are all big pluses
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 12-29-2015, 09:19 PM   #90
Tomahawk30
Tomahawk30's Avatar
I'll check it out! I'll probably just pony up the extra couple hundred bucks for the command center then. Probably money well spent in the long run from the sound of it.
Old 12-29-2015, 09:36 PM   #91
Lattimer
Lattimer's Avatar
I like the idea of the command center because its really an in-tank pump, which is cooled by the fuel, and will last a lot longer. Plus having the surge tank gets rid of the issues with fuel starvation on corners when the stock tank is low (no baffles or sump).
Shawn
Old 12-29-2015, 10:21 PM   #92
steveo3318
steveo3318's Avatar
I put vintage air in my truck this weekend and while doing it I have been running wire and making preperations for the command center return lines. I hope jegs ships mine out tomorrow. Doubtful but hopes are high. If anyone wants I could do a little write up of the install with the command center and everything with a factory tank since I have not seen that particular write up yet.
Old 12-29-2015, 10:49 PM   #93
Lattimer
Lattimer's Avatar
That would be great. I'd especially like to see the command center mounted.
Shawn
Old 12-29-2015, 10:55 PM   #94
Tomahawk30
Tomahawk30's Avatar
That would be awesome! I suspect that this is going to be a common upgrade this year...
Old 12-29-2015, 11:15 PM   #95
steveo3318
steveo3318's Avatar
I will do a write up in a separate post. I will keep y'all informed here though when it gets here and I start the other thread
Old 12-30-2015, 12:12 AM   #96
Crushkrew
Crushkrew's Avatar
Talking Re: Pace performance fitech fuel injection
We ordered a 600 power adder and comand center set up from jegs also....in same boat as you...hoping jegs ships soon....
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510
Crushkrew is offline   Reply With Quote
Old 12-30-2015, 12:52 AM   #97
Nitis
Nitis's Avatar
The impression I got from jegs is most of the FITECH stuff is being drop shipped from FITECH. Could have changed but just an FYI
Nitis is offline   Reply With Quote
Old 12-30-2015, 01:01 PM   #98
steveo3318
steveo3318's Avatar
Yeah I was under this impression as well. I may call fitech
Old 12-30-2015, 01:05 PM   #99
steveo3318
steveo3318's Avatar
Fitech says they will have some in the second week of January. He said jegs may have some in stock though to call them. About to call jegs
Old 12-30-2015, 07:14 PM   #100
Crushkrew
Crushkrew's Avatar
I just spoke with Jegs customer service and they said that when my order was sent to Fitech for shipment, it came back as Backordered to be shipped on 1/13/16...oh well, guess the waiting begins....;(
