#26 |
![]() Join Date: Mar 2015
Re: Starting my engine build
Will be doing this shortly myself, and curious about the comments on not changing the cam at this time. Why not? Does not seem that complicated, and from what I've read the best power increase comes from a good cam/head combo. What would make it so much more difficult to get running again?
#27 | |
One of the reasons to keep track of all the valve train parts is to inspect for unusual wear, if you find something its best to try and figure out if you have a blocked oil passage now rather than after all the new goodies time and labor go into it. EDIT: Did you say its a pretty fresh bottom end in a different conversation? is your compression pretty stable across the board right now? lets hope so because if you have worn rings and put new heads on the engine your gonna end up with a smoker.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 01-09-2016 at 01:16 PM. |
#28 |
From the sounds of it you really need someone to walk you through it. Not trying to be harsh, but I think that you really need to read up on the basics and get advise from someone that has done this before. I am talking about someone that can be with you as you are doing this. A mentor "so to speak". One that can advise you "WHILE" you are doing the work.
Or as stated above, you will have it setting in your driveway for a long time. There is a lot more to this than meets the eye. Even though in the end it is really simple. You said in the first post that you have a buddy to help. How much experience does he have?
Terry Soon to be retired and moving to Bristol, TN. |
#29 | ||||
"I ain't nobody, dork."
![]() Gary
#30 |
A service manual is always good to have but sometimes it is much easier hands on.
I based my comment on the post that the OP made as a reply to my post above about taking pictures so he knows where to put the plug wires back where they belong. In addition, it looks as though the starting thought process could have used some help. Does the OP know any basics on this motor before starting to tear it down? What was the compression? Was a timing light put on it to see if the timing was floating or staying put. Noting that a timing chain could need replacing. ECT.
#31 |
Everyone starts somewhere! Just start slowly, take more notes, more pics, and make sure you've read about what you're going to do from a couple of sources before you do it.
Rebuilding the Small Block Chevy, Chapter 5, Disassembly ![]() Rebuilding the Small Block Chevy Videobook ![]() More advanced than you need, but: Building Small Block Chevrolet Cylinder Heads ![]() I bet all of these are David Vizard. He wrote a lot of good stuff a long time ago. These books are all paperback, under twenty bucks, and available for 2-day Prime delivery. No excuses :-) You'll NEED to know the torque sequence, whether you can reuse rocker arms, which head bolts go into cooling jackets, and all kinds of info you need in "bulk" that you couldn't ask one question at a time. You will need a torque wrench and timing light, and I think you have the latter. If you're anywhere near a major brand parts store, they should rent torque wrenches. You might need to do the chain, but if it's not a known problem I'd keep your battlefield small and not pull the cam and lifters and chain unless it's really time. We used to take them off and lie them on their side and if they touched they were done, but there's likely a much better way, you'll need to ask.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#32 |
To the OP, nothing by me is intentional to be rude or harsh.
Maybe I am old school, Maybe? I know I am because I am older than dirt. Well, I am older than Denny's anyway. But anyway, as Dave noted, Pick up some manuals / books on this and read, read, read.
#33 | |
And the problem is knowing where the parts go is only 50% of the battle. Not to fear, we all started from 0, and there was no internet then. You've got a head start!
#34 |
Great shop. I still enjoy working outside even though I have a garage. Reading manuals will be a big help. Lots of little details not mentioned here yet. Good that you have a buddy for guidance. And the great people of this forums too.
My advice as one who has seen a lot of projects like yours is to seriously consider a cam & lifter set that will match your new heads. An engine should be seen as a total system. In essence, what you have is an air pump and the cam more than any other single component determines how it breathes. This may be a bit intimidating with your current skill level, yet it is the only way you will see full potential from the new heads. Much of this hinges upon what camshaft the engine has right now. Only way to be sure is to pull it and look for numbers.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#35 |
![]() Join Date: Nov 2014
When cleaning the blocks deck(surface that the head mates to) DO NOT use a 2" or 3" Scotchbright wheel. I've seen a tech gouge the deck and then we had to pull the short block. Use a razorblade scraper and take your time. You can also use carb cleaner to soften up the remaining head gasket.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#36 | |
I would call whoever made the heads and see what they suggest, then talk to a cam company and see what they suggest, and maybe pick the milder of the two suggestions. The cam company would need to know the lift vs flow numbers to make a good recommendation, but even just knowing what approximate type of head they are they can make a decent guess based on what you want the vehicle to do and how you want it to drive, what gears it has, what weight it is, what converter you have, all of that.
#37 | |
#38 |
The heads are Pro Topline SRT 180cc runners, 64cc chambers and 2.02 intake 1.64 (I think) exhaust. Not aluminum as far as I can tell, but they do have comp cams guides plates on them already, and springs as well.
#39 |
The heads
#40 | |
Hey Dave, do you know if the head company is still around anymore? |
#41 |
Some of you wont like the name the PO used for the cam, and I agree, but when I bought it the guy said he thought it was an RV cam. Before you jump me for using "RV cam" I'm just repeating what PO said lol GASOLInE
#42 |
I'll add, the guy who actually built the truck, used it to tow his OTHER 1970 c10 to the track, said truck being a 10 second shortbed with full cage and wheelies and all that. So, the guy knew a thing or two about motors, this is good news to me.
#43 |
Your last couple posts answered my question about the bottom end & possible wear.
Nothing wrong with an "RV" cam. That is a common upgrade and I have built many for customers with one. Would be great if you could get build info, including part numbers, from the PO. |
#44 | |
#45 | |||
![]() Sounds like you're getting your hands dirty. Check back in if you have more questions. Gary
#46 | |
Here's a link on degreeing your cam. You can find all the specs you need by leaving it in the block. Just need a few parts. Like a degree wheel and dial indicator and some patience. http://www.lunatipower.com/Tech/Cams...egreeACam.aspx |
#47 |
![]() Join Date: Dec 2013
Reading your thread and I did a few quick searches on Pro Topline heads and before you dive in to this head change you may want to do some homework on these heads ? Seems many think there junk and not worth the time and aggravation ? That maybe why the PO handed them to you instead of installing them when he just did the bottom end ? Their made in New Zealand and the company was sold 12 years ago
![]() http://www.hotrodders.com/forum/pro-...uck-26435.html Last edited by Grumpy old man; 01-09-2016 at 06:46 PM. |
#48 | |
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#49 |
If the block has the cross hatches from the last hone job you should be good to go. Might be a good idea to grab a double roller timing set and spring for some roller rocker arms. I'd also check with head manufacturer to see if you need different length push rods.
good luck there's plenty of good help here if you need it
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. ![]() |
#50 | |
