#451 | |
Re: 53 Surburban "Family Truckster"
#452 |
A320 Pilot/USAF Retired
Brakes look good!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#453 |
Looking good on the truck Marc - the Eastwood deal is pretty good for $949 if you can find it with free shipping. I payed $800 for both but I got stiffed for shipping of about $80 -$90 I think it was.
They both work great so far.... plasma cutter is doing 3/8" plate and burns right thru. I found if you use TOO much air its NOT good... trial and error! The welder works good on 18ga, 16ga that ive been welding lately and then 1/4" and 3/8" plate too. good luck!
My Build: 57 Chevy Pro-Street |
#454 | ||||
![]() Join Date: Mar 2007
Thanks Jim
Tryin...Thanks Quote:
Thanks man Quote:
Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#455 |
Had a pretty productive Sat. I found a ZR2 s-10 rear-end for cheap on CL about an hr east of me. When trying to get a buddy to go along, one of my friends tells me he had to pick up a open car trailer he had built that was in the same area.
We left by 8 am, picked up the rear end and then the trailer. Stopped for breakfast and was home by 12:30. On Sunday, I spend an hour or so cleaning up the rear end. I removed the track arm and other crap that I would be needing. All ZR2 rear-ends are posi with 3.73 gears so it should be perfect plus the bolt pattern will match my front. Here are a few pics Marc
#456 |
Wow 13" rotors. I thought my 12" rotors where a huge upgrade. Nice job on the frame. That rear end should work great.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#457 |
![]() Join Date: Jul 2012
That rear was a nice find Marc. Having a good friend with a trailer is maybe better than owning one!
#458 | |
Marc
#459 | |
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#460 |
Ha! I thought the same. Nice work Marc.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#461 |
No...my Suburban is a 53. My truck is a 48. I was messing with my friend saying my truck will look good on his trailer. I only trailered it to the Columbus GG show last yr because my buddies cars were not done yet. I drive my 48 as much as possible. The suburban I don't plan on it having nice paint so I plan to drive it as much as possible.
Marc
#462 |
That's good to hear Marc..
NO life size Matchbox cars!! ![]()
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#463 |
I was just foolin' around Marc
![]() I know you build fantastic drivers!! ![]()
#464 |
I got out in the garage for a few hours on Sunday. After church on Sunday's seems to be the norm for getting out there.
I worked on getting the rear end, watts link and trailing arms set up. Keep in mind I mounted the axle pads upside down and didn't realize it until someone pointed it out on IG. Funny how things look soooo obvious after someone else points it out....ha ha. It's all good, this is why we mock stuff up first. Marc
#465 |
Marc, that looks really trick! Usually I would figure out the pads were on the wrong side after I welded them on. Good catch.
#466 | |
Marc
#467 |
Looking pretty slick..
Mark...
#468 |
![]() Join Date: Mar 2010
Looking great.... Keep the pic's coming.
#469 |
That looks like a strong set up !!
#470 |
Very impressive!
#471 |
I have been working hard to get the frame to a roller. I was close on sat then I realize my 15" roller rims would not clear the dropped spindles. Then I realized that I could steal two 17" rims off my Camaro.
I need to replace the front wheels studs to match the ones in my rear end. the plan is to barrow my friends LS mock up block to see how the f-body exhaust manifolds fit. Pretty stoked to see it laid out. Marc
#472 |
Looking good!
#473 |
That looks very good Marc! It is a good feeling to have a roller.
Those PB parts are beautiful and makes me want to build something with them. Ah, so many cool ideas, so little time and money. Good luck with the exhaust fitting. Hopefully Camaro manifolds will work. |
#474 |
Look's Badass Marc...Those Camaro meats look huge!! I like it.
Mark...
#475 |
![]() Join Date: Mar 2011
Marc, very nice and looks super...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
