Old 01-15-2016, 12:22 PM   #451
jweb
jweb's Avatar
Re: 53 Surburban "Family Truckster"
Originally Posted by youngrodder View Post
So I have been working through some minor set backs with my chassis. Nothing too serious. I have also been collecting some parts.
First I received my 13" big brake kit. Man these rotors and calipers look huge. I wanted to go with the 14" set up but I couldn't justify the extra cash when I still have so much money to spend...
Marc
Which brake kit did you use?? I think I need to upgrade since my ls1 swap
jweb is offline   Reply With Quote
Old 01-15-2016, 02:25 PM   #452
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Brakes look good!
ChuckDriver is offline   Reply With Quote
Old 01-15-2016, 07:33 PM   #453
ptc
ptc's Avatar
Looking good on the truck Marc - the Eastwood deal is pretty good for $949 if you can find it with free shipping. I payed $800 for both but I got stiffed for shipping of about $80 -$90 I think it was.
They both work great so far.... plasma cutter is doing 3/8" plate and burns right thru. I found if you use TOO much air its NOT good... trial and error!
The welder works good on 18ga, 16ga that ive been welding lately and then 1/4" and 3/8" plate too.
good luck!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 01-15-2016, 11:23 PM   #454
youngrodder
youngrodder's Avatar
Originally Posted by oldman3 View Post
Marc, Frame is looking good...Jim
Thanks Jim
Originally Posted by 99 to Life View Post
looking good
Tryin...Thanks
Originally Posted by Advanced Design View Post
Those brakes do look huge! Way more stopping power than anything the Burb ever had.
Chassis is looking good. Good luck with the ZR2 rear Marc.
Yes Doug I was surprised how big the rotors and calipers were. We leave at 8:30 am tomorrow to go grab it.
Originally Posted by 48ChevBagged View Post
I have not been on in a while but the burb is looking great. Keep it up.
Thank you
I went with mcGaughy. That's who's dropped spindles I'm using. 13' will be fine a 14" set up would be overkill for my stock 350 hp LS1 motor.
Originally Posted by ChuckDriver View Post
Brakes look good!
Thanks man
good luck!
Thanks for the info, I appreciate it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 01-17-2016, 11:03 PM   #455
youngrodder
Had a pretty productive Sat. I found a ZR2 s-10 rear-end for cheap on CL about an hr east of me. When trying to get a buddy to go along, one of my friends tells me he had to pick up a open car trailer he had built that was in the same area.
We left by 8 am, picked up the rear end and then the trailer. Stopped for breakfast and was home by 12:30.
On Sunday, I spend an hour or so cleaning up the rear end. I removed the track arm and other crap that I would be needing. All ZR2 rear-ends are posi with 3.73 gears so it should be perfect plus the bolt pattern will match my front.
Here are a few pics
Marc
Old 01-18-2016, 09:39 AM   #456
lower50's
lower50's's Avatar
Wow 13" rotors. I thought my 12" rotors where a huge upgrade. Nice job on the frame. That rear end should work great.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-18-2016, 04:26 PM   #457
Advanced Design
Advanced Design's Avatar
That rear was a nice find Marc. Having a good friend with a trailer is maybe better than owning one!
Advanced Design is offline   Reply With Quote
Old 01-18-2016, 11:15 PM   #458
youngrodder
Yes, when we picked it up I said "My 48 will look nice on that trailer"...ha ha
Marc
Old 01-19-2016, 06:14 AM   #459
RockinKees
RockinKees's Avatar
Marc
You're not building a Trailer Queen, are you??
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-19-2016, 09:56 AM   #460
FarmerSid
FarmerSid's Avatar
Ha! I thought the same. Nice work Marc.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 01-19-2016, 10:28 PM   #461
youngrodder
No...my Suburban is a 53. My truck is a 48. I was messing with my friend saying my truck will look good on his trailer. I only trailered it to the Columbus GG show last yr because my buddies cars were not done yet. I drive my 48 as much as possible. The suburban I don't plan on it having nice paint so I plan to drive it as much as possible.
Marc
Old 01-20-2016, 10:24 AM   #462
reaper71
reaper71's Avatar
That's good to hear Marc..
NO life size Matchbox cars!!
reaper71 is offline   Reply With Quote
Old 01-21-2016, 06:22 AM   #463
RockinKees
RockinKees's Avatar
I was just foolin' around Marc
I know you build fantastic drivers!!
Cheers!! Kees.
Kool Guyz CC
Old 01-31-2016, 10:40 PM   #464
youngrodder
I got out in the garage for a few hours on Sunday. After church on Sunday's seems to be the norm for getting out there.
I worked on getting the rear end, watts link and trailing arms set up. Keep in mind I mounted the axle pads upside down and didn't realize it until someone pointed it out on IG. Funny how things look soooo obvious after someone else points it out....ha ha. It's all good, this is why we mock stuff up first.
Marc
Old 01-31-2016, 10:51 PM   #465
Advanced Design
Marc, that looks really trick! Usually I would figure out the pads were on the wrong side after I welded them on. Good catch.
Old 01-31-2016, 11:01 PM   #466
youngrodder
Thanks Doug, this is my first time messin with a watts link. Yea I hear ya, me too normally. If I hadn't ran out of time maybe I would have welded them on wrong.
Marc
Old 02-01-2016, 10:32 AM   #467
reaper71
reaper71's Avatar
Looking pretty slick..
Mark...
Old 02-01-2016, 02:36 PM   #468
69CST-V
69CST-V's Avatar
Looking great.... Keep the pic's coming.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 02-01-2016, 04:18 PM   #469
lower50's
lower50's's Avatar
That looks like a strong set up !!
1951 MG TD
Old 02-01-2016, 04:30 PM   #470
RockinKees
RockinKees's Avatar
Very impressive!
Cheers!! Kees.
Kool Guyz CC
Old 02-28-2016, 11:12 PM   #471
youngrodder
I have been working hard to get the frame to a roller. I was close on sat then I realize my 15" roller rims would not clear the dropped spindles. Then I realized that I could steal two 17" rims off my Camaro.
I need to replace the front wheels studs to match the ones in my rear end.
the plan is to barrow my friends LS mock up block to see how the f-body exhaust manifolds fit.
Pretty stoked to see it laid out.
Marc
Old 02-28-2016, 11:39 PM   #472
whiteheadcycle
Looking good!
whiteheadcycle is offline   Reply With Quote
Old 02-29-2016, 09:51 AM   #473
Advanced Design
That looks very good Marc! It is a good feeling to have a roller.
Those PB parts are beautiful and makes me want to build something with them. Ah, so many cool ideas, so little time and money.
Good luck with the exhaust fitting. Hopefully Camaro manifolds will work.
Old 02-29-2016, 10:12 AM   #474
reaper71
reaper71's Avatar
Look's Badass Marc...Those Camaro meats look huge!! I like it.
Mark...
Old 02-29-2016, 11:19 AM   #475
oldman3
oldman3's Avatar
Marc, very nice and looks super...Jim
oldman3 is offline   Reply With Quote
