![]() Join Date: Dec 2014
Ridetech suspension problem.
I just set the bed on my truck after doing the wood floor and the ridetech cross bar that the coilovers mount to are hitting the wood floor. It's making the floor bow up in the center. I was thinking of adding spacers under the cross bar to lower it but I'm afraid it's gonna make my truck sit too high in the rear. I'm starting to think this kit was designed for a steel floor truck. You guys have any suggestions besides calling ridetech Monday morning. 😩
Re: Ridetech suspension problem.
![]() Join Date: Oct 2014
How thick of a spacer do you need for clearance? You can lower the spring seat on the coil over shock to lower your ride height back down where it was assuming you have that much adjustment. You will, however, lose some compression travel.
I'm thinking about a 1/4" maybe a bit more. How do I lower the spring seat?
Support the rear of the truck on jack stands on the frame letting the rear end hang. There is a collar that the spring rests on on the bottom of the shock. There is a bolt that clamps the collar tight on the shock, loosen that bolt and unscrew the collar 1/4 to 1/2 inch, tighten the collar bolt. That will let your suspension collapse more to regain your ride height. You don't show a pic of the lower part of the shock so I'm going off of memory. Did you get a spanner wrench with the coil over kit? You use that to unscrew the collar.
#7 | |
You could try the spacer like you say, then drill a couple more holes inward, it would increase the angle of the shocks tho.
I know i have see shock relocater's for the bottom of the shocks on these trucks, nor sure who makes them tho.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
There's very little clearance under the bed wood, even near the stock frame rail. We made our own coil over set-up for the rear (and tried a release on here 6 months before ridetech released theirs) and had rubbing issues just on the bolt heads that replaced the factory rivets for the coilover crossmember. When I saw the first pics of the ridetech kit, I though there was no way that their cross member is going to clear the bottom side of the bedwood after having issues with just the added thickness of flat washers and bolt heads. There's only about a 1/8" of clearance over the factory frame rails at the high point where the factory shock crossmember is, just enough to clear the rivets that tie in the crossmember. Luckily for me, the body lines on my bed were about a 1/4" low, so I made some spacers out of billet aluminum to shim the entire bed up to match the body lines of the cab.
#10 | |
#11 | |
Ride tech does have a forum you wanna post your pictures on it.
Old member
No limit's shock relocator is another option.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I've got it all figured out and it's back on the ground. Just had to add some 1/4" spacers and adjusted the collar on my coilover for the ride height. Thanks guys
#15 | |
![]() Join Date: Jun 2013
chase |
#16 |
Thanks Chase. I gave you guys a call last week and we have it all figured out. Thanks again for the help!
#17 |
Their shock relocation brackets are not built to support coil-overs.
