Old 01-30-2016, 06:32 PM   #4
RodnRudy
RodnRudy's Avatar
Re: Ridetech suspension problem.
How thick of a spacer do you need for clearance? You can lower the spring seat on the coil over shock to lower your ride height back down where it was assuming you have that much adjustment. You will, however, lose some compression travel.
RodnRudy is offline   Reply With Quote
