02-11-2016, 09:46 PM | #251 |
Re: A 15 year old's project. Rusty 62 stepside
Picked up some stainless steel bolts for my rear fenders. Instead of buying the expensive ones from lmc, I went to a fastener supplier and told him what I was looking for and that they were for my old truck and he gave em to me for $15
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
02-11-2016, 09:47 PM | #252 |
01
02-11-2016, 11:10 PM | #253 |
The fan looks good cleaned up. It probably takes about the same power as a heater blower so your alt. should be fine to drive it. Don't forget to use anti seize on the stainless bolts.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
02-11-2016, 11:38 PM | #254 |
Thanks dale
02-12-2016, 02:31 AM | #255 |
02-13-2016, 10:38 PM | #256 |
Fixed all the rust in the tailgate today. this was a bit of a difficult one, I had to make the bends using my own ghetto metal brake. It consisted of two thick and long pieces of angle iron in a vise and lots of other clamps. And the steel was donated from the hood of a 73-87 truck. In the small lip I drilled holes and filled them with spot welds. I'm pretty happy with it, the welds still need to be ground down.
Here's before: |
02-13-2016, 10:38 PM | #257 |
The cut:
02-13-2016, 10:39 PM | #258 |
And all welded up:
02-13-2016, 10:40 PM | #259 |
02
02-13-2016, 11:14 PM | #260 |
Good job!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-14-2016, 01:49 AM | #261 |
Nice job
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
02-14-2016, 09:49 AM | #262 |
02-14-2016, 12:42 PM | #263 |
Thanks guys
02-15-2016, 10:52 PM | #264 |
The cast aluminum base of the fan had 3 out of 4 corners cracked off and only one hole left so out came the long strand fibreglass. Turned out pretty strong. After lots of sanding and redrilling the holes it looks right again, a coat of paint and you won't even be able to see where it broke.
02-17-2016, 12:15 AM | #265 |
Hello everyone, I hate to admit it but I screwed up. The panel that I just put on the tailgate didn't quite workout the way I wanted, I tried to keep as much of the original metal as possible but ended up messing up the line because some of it was new and some of it was the old metal and the bends didn't line up correctly. I wanted it to be right so out came the angle grinder with cut off wheel. I then made a new panel and made it go down the same amount all the way across. Got it welded on but still need to grind the welds down. I'm very satisfied with it now it's pretty much perfect.
The old panel ripped off |
02-17-2016, 12:16 AM | #266 |
The new panel welded on, done the right way.
02-17-2016, 12:19 AM | #267 |
Also cut the hooks for the tailgate chains off as I'm going to eliminate the chains and use cables on the inside
02-17-2016, 12:20 AM | #268 |
And another pic of the new panel
02-17-2016, 01:28 AM | #269 |
Looking good!
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
02-17-2016, 01:32 AM | #270 |
Thanks John, as I said above I want to do it right. I could just buy new panels but building them is cheap but most importantly it's a great way to learn metalwork
02-17-2016, 01:45 PM | #271 |
Good work!
02-17-2016, 03:01 PM | #272 |
In for the build. Wish my metalwork/welding skills looked like yours.
'66 GMC K25 (305 V6, SM420) aka "Mabel" Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082 All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado |
02-17-2016, 07:03 PM | #273 |
Very nice work!
02-17-2016, 08:25 PM | #274 | |
Thanks tj
Thanks bill
02-18-2016, 11:49 AM | #275 |
the rear cab mounts/cab corner area is going to be the most challenging spot and I'm thinking of getting started on them soon but they are so rusty I don't don't what there supposed to look like. It would be great if someone could get a picture of the rear cab mounts/cab corner. Thanks
