Old 02-11-2016, 09:46 PM   #251
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Picked up some stainless steel bolts for my rear fenders. Instead of buying the expensive ones from lmc, I went to a fastener supplier and told him what I was looking for and that they were for my old truck and he gave em to me for $15
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-11-2016, 09:47 PM   #252
62stepside longbox
01
Old 02-11-2016, 11:10 PM   #253
65sub
65sub's Avatar
The fan looks good cleaned up. It probably takes about the same power as a heater blower so your alt. should be fine to drive it. Don't forget to use anti seize on the stainless bolts.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 02-11-2016, 11:38 PM   #254
62stepside longbox
Thanks dale
Old 02-12-2016, 02:31 AM   #255
AJCK87
Originally Posted by 62stepside longbox View Post
Thanks dale
Cool man, yeah I'm going stainless where I can too!
AJCK87 is offline   Reply With Quote
Old 02-13-2016, 10:38 PM   #256
62stepside longbox
Fixed all the rust in the tailgate today. this was a bit of a difficult one, I had to make the bends using my own ghetto metal brake. It consisted of two thick and long pieces of angle iron in a vise and lots of other clamps. And the steel was donated from the hood of a 73-87 truck. In the small lip I drilled holes and filled them with spot welds. I'm pretty happy with it, the welds still need to be ground down.
Here's before:
Old 02-13-2016, 10:38 PM   #257
62stepside longbox
The cut:
Old 02-13-2016, 10:39 PM   #258
62stepside longbox
And all welded up:
Old 02-13-2016, 10:40 PM   #259
62stepside longbox
02
Old 02-13-2016, 11:14 PM   #260
TJ's Chevy
TJ's Chevy's Avatar
Good job!
Old 02-14-2016, 01:49 AM   #261
Classic v6 GMC's
Classic v6 GMC's's Avatar
Nice job
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 02-14-2016, 09:49 AM   #262
Old 02-14-2016, 12:42 PM   #263
62stepside longbox
Originally Posted by TJ's Chevy View Post
Good job!
Originally Posted by Classic v6 GMC's View Post
Nice job
Thanks guys
Old 02-15-2016, 10:52 PM   #264
62stepside longbox
The cast aluminum base of the fan had 3 out of 4 corners cracked off and only one hole left so out came the long strand fibreglass. Turned out pretty strong. After lots of sanding and redrilling the holes it looks right again, a coat of paint and you won't even be able to see where it broke.
Old 02-17-2016, 12:15 AM   #265
62stepside longbox
Hello everyone, I hate to admit it but I screwed up. The panel that I just put on the tailgate didn't quite workout the way I wanted, I tried to keep as much of the original metal as possible but ended up messing up the line because some of it was new and some of it was the old metal and the bends didn't line up correctly. I wanted it to be right so out came the angle grinder with cut off wheel. I then made a new panel and made it go down the same amount all the way across. Got it welded on but still need to grind the welds down. I'm very satisfied with it now it's pretty much perfect.
The old panel ripped off
Old 02-17-2016, 12:16 AM   #266
62stepside longbox
The new panel welded on, done the right way.
Old 02-17-2016, 12:19 AM   #267
62stepside longbox
Also cut the hooks for the tailgate chains off as I'm going to eliminate the chains and use cables on the inside
Old 02-17-2016, 12:20 AM   #268
62stepside longbox
And another pic of the new panel
Old 02-17-2016, 01:28 AM   #269
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Looking good!
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 02-17-2016, 01:32 AM   #270
62stepside longbox
Originally Posted by Johnny_Lamebridge View Post
Looking good!
Thanks John, as I said above I want to do it right. I could just buy new panels but building them is cheap but most importantly it's a great way to learn metalwork
Old 02-17-2016, 01:45 PM   #271
TJ's Chevy
TJ's Chevy's Avatar
Good work!
Old 02-17-2016, 03:01 PM   #272
BFoley
BFoley's Avatar
In for the build. Wish my metalwork/welding skills looked like yours.
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 02-17-2016, 07:03 PM   #273
Very nice work!
Old 02-17-2016, 08:25 PM   #274
62stepside longbox
Good work!
Thanks tj
Thanks, I've found the only way to get good at something is to do it. I've only been doing this for a year and with all the rust I've gotten decently good at it.
Very nice work!
Thanks bill
Old 02-18-2016, 11:49 AM   #275
62stepside longbox
the rear cab mounts/cab corner area is going to be the most challenging spot and I'm thinking of getting started on them soon but they are so rusty I don't don't what there supposed to look like. It would be great if someone could get a picture of the rear cab mounts/cab corner. Thanks
